- 6 Sep 2016
Well my amp doesn't have arc or sound though hdmi.. That is the main issue
ok but check your TV supports all the formats.
ARC/E-ARC is useful but I'd view it as additional connection, I personally prefer device through the AVR. Also allows you set to custom inputs, ie no EQ for HDMI 1, EQ for HDMI 2 etc. With everything going through the TV then you have a unified setting for E-ARC input...plus as I said you lose OSD for OSD volume and AVR setup so you'd need to switch over to input from AVR to TV just to get OSD for AVR setup.
Similar issue with people with soundbars, they're stuck in using E-ARC (as the soundbar only has E-ARC audio input) but the TV doesn't support DTS...so DTS 5.1, DTS HD and DTS X won't work...just get stereo sound lol
