Sounds like it's an XL panel issue.My Pixel 10 Pro 256gb Moonshine has arrived. I have switched on & set a white background. All seems good not pink tints..
Not sure if this is going to be a software thing, fixable by an update.
Yea - hadn't noticed on mine 10 Pro XL but now you've mentioned it, there is definitely a pink hue - particularly off axis as mentioned above.
Looking for a new phone to replace my S23+ but the 10 pro XL pink tinted screen is concerning for me. Are they all slightly pink/overly warm in tone?
There is another thing I have noticed on the XL in camera the preview has very saturated colours but after taking the pic and processing it looks ok. 10 Pro doesn't have this issue.
Are you using Natural mode or Adaptive mode in display settings? Not camera settings, but the main display settings in the phone's main settings menu.
I found changing this from the default Adaptive mode to Natural removed the over saturation
Who thinks it's worth waiting out the release of the S26 series over the Pixel 10? They're not too far away now. Coming from an S23+.
Nice!!
XL? Can you check the tint against another phone?So far screen is white
Good impressions how it feels in hand
Mous case - as it has only cutouts for buttons we will see how I get along with it in compare to previous Google case with case buttons.
Still downloading the apps so all CPU is used by that.
Happy so far
Have it next to p8proXL? Can you check the tint against another phone?
I'm tempted to return mine and gamble on the next one being better.
Nice one cheersHave it next to p8pro
Diff screens so hard to match those in terms of brightness.
But definitely looks white - for me.
At first it was adaptive brightness that had all pinkish etc
Will see if I can take a photo with normal p8 later
I have a mous superthin but not the clear version. The clear version is super slippery the black version I got with the microfibre on the inside is super grippy.official Pixelsnap case arrived today for the P10 Pro, indigo version… jinkies it’s slippy! Looks great, but I’m definitely throwing the phone across the room if I stick with this case.
I've got the lightweight.I have a mous superthin but not the clear version. The clear version is super slippery the black version I got with the microfibre on the inside is super grippy.
Ideally I'd love to be bareback but my phone drops once or twice a year but that's too much to be able to cope with no case.
It's ok for now but if you leave it on the angle on the sofa it will slip when not horizontal. P8 case would stay there .
For me biggest test will while cycling and getting phone out on the move and taking phone out from a rear pocket.
Might try your one ... As long is not as grippy as P8 case...
Just send it back! You're clearly not happy with itCan you do it at an angle?
Did you sort this?Finally got the 10 Pro XL set up and I can't transfer maps timeline over, it says it's imported but nothing appears. FFS, literally the last thing to do and now it looks like I'll have to start over. I've tried every fix I can find and nothing works.
