- 22 Dec 2006
- Around Town
It's Autumn, time to get the Weed out!
I got a bit wet this morning on the bike
Its supposed to be thunder at mid day, and hopefully no rain for the ride back after work
You still have a fan working?!It's still humid can't wait to feel the last of it can't be long now, at least the fan is effective compared to during the heat wave
I have both my heated blanket and heat pad on and all my windows closed now and can feel the heavy weight of autumn depression getting stronger and more debilitating day by day.
Always the way.Finally had enough rain to fill up the 9 water butt's -First time since added the new ones in early summer.
Probable won't need them now.
Its been too hot indoors fan has only just been turned off the last day or two. Our housing just isn't built to cope with these temperatures the care home my mothers in is a new build and its got air con built in as standard and its always comfortable in there thats the future but the expense of retrofitting our ancient housing stock is going to be immense it ought to be standard fitting on new builds now but as usual we're well behind the timesNew build home, even with the grey wet weather the house is like a furnace!
I dont know what my room temp is but I do prefer to wear as little clothing as possible.Fan isn't at it's fastest just a nice cool breeze Thermometer is showing room temp at 24c that's with the windows open the TV acts like a heater according to the forecast it's 18c outside
I'd be interested what the room temp is for you to have heated blanket and heat pad on and windows closed
Past week I've had the best sleeps in awhile
Not sure what room temp will take to start closing or slightly leaving the windows open without any extra heating, the TV is usually enough over the winter and under a blanket
How is life in Alaska?You still have a fan working?!
