Caporegime
- 30 Jul 2013
That's the first gameJust about to buy this then found it on PC gamepass![]()
Silksong is also on GPThat's the first game
silk is also thereThat's the first game
First one is widely considered one of the best metroidvanias ever. Difficulty ranges from standard Metroidvania difficulty up to ballbustingly hard in the optional endgame stuff.There was one before this? Should I play it first? Have started this one, like what I’ve seen so far. Is it easier than Ori though?
Yeh, i'd probably go with the first one. It's 1st class, and won't feel outdated. Then you have Silksong to look forwards to. Difficulty can spike at times, but if i die it never feels cheap. As mentioned above, some of the endgame stuff can be extremely hard.There was one before this? Should I play it first? Have started this one, like what I’ve seen so far. Is it easier than Ori though?
Cripes...
Even the soundtrack is in the Steam Top 10.
I don't remember seeing a sountrack in the Top 10 period!
No. Because this isn’t real.Anyone else get this screen after 10hrs?
U kno it bossNothing gets past this guy
There’s no need to play the first one to get into this. I’d highly recommend playing it though, It’s one of the best metroidvaniasDo you need to have played the first game? Or can you just pick this up?
