New Anno - Anno 117 Pax Romana
Demo Bypass is out.
Maybe someone can try it.
Open the Anno117.exe in your Hex editor of choice (https://hexed.it/)
Go to the offset 0x02952a43
It's the 15th 80 EE 36 00 (3,600,000)
Edit to the number you want in milliseconds
The max would be 1000+ hours with FF FF FF FF (4294967295)
Save and then run
Works a treat! The only issue was I was enjoying it so much, I forgot you can't save in the demo!
:cry:
Does it actually give you the next tiers of buildings etc though, or does it just give you "unlimited" time but you just get like 1000 hours of the basic buildings
Yes, you get new tiers and buildings :)
Are you sure?
I played the Celtic one yesterday and still seemed to cap out at 2 tiers.
Nonetheless, it was nice playing it at my normal leisurely pace.
I saw one of the devs mention on Reddit that this is a build from a couple of months ago, so a few bugs etc that are in the demo have been fixed in the current code.
I couldn't figure out for the life of me how to get troops onto a boat, but may just not be possible in the demo.
Are you sure?
Yeah the devs said that the demo is from June so an old build, they also said that game balance in the demo is all out of whack because the balance and speeds of things have been altered to take into account a 1 hour play time so the balance is not reflective of the balance of the full game.
Well its gorgeous graphically, runs a bit slow on my ti super 4070 mind you. Hopefully be a bit more optimised upon release.
Its annoying you can't save, and the UI is a bit cumbersome, to say the least. Its clearly designed for consoles unfortunately. That said, at super high resolution it is gorgeous and I'll definitely be getting it.
