Did they update your tracking after you paid? I had to call them up before mine got updated
Same here, was just sat doing nothing, I had to get in touch. Seemed a stupid way of doing things.Did they update your tracking after you paid? I had to call them up before mine got updated
I meant UPS not DHL. Too may TLAs about!!This was UPS so they all seem as bad as each other![]()
Could I ask where did you source the RAM from? I don't see anywhere in the UK I could get SODIMM ECC DDR5 for this cheap (shop_name is 180 quid for 32gb, for example). Is this the full side-band ECC?I got a single 32Gb Lexar ECC 5600mhz for £68. I didn’t got looking for ECC but it was the same price as non ECC memory so it would’ve been daft not to get it. It’s been in my Aoostar since I got it with no issues
It’s gone up in price slightly since I bought it the massive America company that can’t be named. It’s only in the detailed description of the memory that ECC is mentioned btw.Could I ask where did you source the RAM from? I don't see anywhere in the UK I could get SODIMM ECC DDR5 for this cheap (memorycow is 180 quid for 32gb, for example). Is this the full side-band ECC?
From what I can see, the Lexar sticks aren't full ECC, they just have the 'on-die' ECC that all DDR5 modules have. Cheapest option I saw for the real stuff was from Kingston and even that is almost £350 just for 64GB, so I gave it a pass for nowCould I ask where did you source the RAM from? I don't see anywhere in the UK I could get SODIMM ECC DDR5 for this cheap (shop_name is 180 quid for 32gb, for example). Is this the full side-band ECC?
Fair enough. It wasn't something I was looking out for or thought I needed. I did think it was a tad cheap for what it was offeringFrom what I can see, the Lexar sticks aren't full ECC, they just have the 'on-die' ECC that all DDR5 modules have. Cheapest option I saw for the real stuff was from Kingston and even that is almost £350 just for 64GB, so I gave it a pass for now
Unraid here. I’ve been using it for seven or eight years across three or four server builds and it was yet another easy transfer across to the AoostarIt arrived, NAS software are people using ?
TrueNAS.It arrived, NAS software are people using ?
wow that is high. i dont have a device but instead have a full tower pc with approx 12 drives(7 hdd, 5 nvme) inside it running truenas and mine idles at 80w all things considering its a desktop 5600 AMD cpu.Hi all,
I just received mine and transferred unraid over - no problems there.
My initial observation is it seems to be using quite a bit of power, GPU reporting 16-36W and nothing is using it, though I don't know whether that's accurate, the draw at the socket is around 60W.
Wondering if anyone else is seeing this?
Matt
From the NAS Compares review:Hi all,
Matt
