What's your go to Beef Burger Patties?
I used to throw in all sorts to the mix, mince, bread crumps, herbs, egg, salt & pepper, onion, now, and you cant beat it, I just buy some 15% fat mince, and portion it out into equal weights, and press them in a burger press, and throw them on the bbq.
Mostly make my own with 3 different steaks using a decent sized mincing machine at home and after adding blitzed crackers, eggs and cracked pepper are hand rolled into a ball slightly smaller than a tennis ball and thrown between hands, spinning as doing so to form a tightish ball.
Sometimes I may add some diced onion or small cubes of cheese or garlic...It really depends on what is around that needs using, or I fancy throwing in.
Buying out, we've enjoyed the Sainsburys and Aldi Wagyu burger, that if not overcooked, makes for us a decent burger.
The OH prefers the steak burgers to be as we have in France, with the word 'Smashed' not one used in our kitchen
Sometimes I may add some diced onion or small cubes of cheese or garlic...It really depends on what is around that needs using.
Try with a splash of Hendersons, it's bit of a game changer.
But frankly I think the best will always be just seasoned mince smashed on to a hot cast iron pan so it gets a good crust. Let the burger toppings do the fancy stuff.
Yup agreed.
Don't get me wrong I've experimented a lot as well, but I've come to the conclusion save the fannying about and just keep them simple.
Personally I use a big wide frying pan to cook on and a circular metal pan lid to squash the patty down. Works well enough.
Similar to this - a big cast iron griddle (on the flat side), and I use the bottom of a milk pan (with a bit of parchment paper over it) to smash.
I much prefer 2 x thin patties to 1 x thicker these days. Approx 62g per pattie.
I do like to make my own, but if being lazy and getting premade I go for the Aldi Aberdeen Angus ones. They're pretty tasty.
20% mince, usually 500g packet.
Pick up the size that I want from the packet, usually 1/4.
Place on hot pan.
Smash it down.
Season.
Is there any other way? :p
Approx 100g per pattie (X2) rolled into balls lightly seasoned. Pre heat cast iron skillet. "Smash" patties onto skillet with steel spatula for a few mins each side til you can see a nice crust. Job done.
