Does anyone else wish that RGB would just die?
You almost have no choice now, most high end hardware has built in RGB and you can't even disable it without installing bloatware
It's not easy to build a top of the line system and avoid any components with RGB. The hardest components to deal with is motherboards and RAM because almost all top of the line boards and memory kits have built in RGB
It's actually easier to just use a closed case, use a pc case that has no windows then you won't have to see the RGB
That's a whole other problem, the lack of cases without windows
That's why I installed Bazzite on mine...
Badum-tsh (sorry :p)
RGB is for suckers. Proper gangsters use cold cathodes.
Amateur, what you need is a couple of tallow candles with stained glass in front of them.
On a totally unrelated note, I still need to figure out why my GPU keeps overheating...
Serious response - I don't mind it, like everything else, when done tastefully it can look good, a few carefully placed lights/bars in carefully selected colours - great. A tsunami of unicorn vomit covering every possible component and surface - no thanks!
I think you've head the nail there, it's 'tastefully' done otherwise you end up in a very strange place.
Whilst ordering some coffee related stuffs on Ali-X I happened to see a RGB AIO sleeve kit which obviously I immediately bought.
It’s so beautiful/hideous I’m not sure I should post a pic on here as it may send some over the edge.
I don't like it either. I have a solid side panel so I don't have to see it or deal with it. I had to buy my solid side panel separately though, Corsair only offered it with a window (750d airflow).
