Nope.Is there much in the way of tweaking required to get these processors running optimally?
Nope.
count yourself lucky.. 14900k is running close to 200 watts!
Yeah, if anything more effort is required on the software side. As you need to install the latest Chipset drivers and update Windows Game Bar, use the Balanced power profile and keep Game mode enabled in Windows. Hardware side you can run it as out of the box and just enable EXPO for plug and play.Plug and play?
Fit and forget.I have an opportunity to get a 9950x3d at a good price. No serious use case. Is it a fit and forget if coming from a 9800x3d (just re-install chipset drivers) or is there still some games that you have to arse around with windows settings for ?
I've yet to run it, will share when I do. Usually if you can pass those tests then Karhu will be fine too.Karhu stable?
Some further refinement of my 8300MhzC34 tune, low voltages all round.
[/spooiler]
8400Mhz is a work in progress.
Karhu is a good test for long term stability. It highlight any temperature issues in your setup over long runs, it'll check for memory issues and it'll eventually sniff out issues if your FCLK is not happy. For short term stability tests there are better options though, as you mentioned. I like running Y-Cruncher a lot these days too, it's like Karhu but condenses into an hour or more tests. Download Y Cruncher and type 2, enter, 8, enter, 15, enter, 16, enter, 17 enter, 18 enter, then type 3600 enter, then 0 and enter. That'll test FCLK, memory and CPU. If you can pass that you'll pass most things.Nice, might have another look at mine, I do have that same kit of ram in my Mrs PC, ive been thinking lately of swapping it over with my kit to see if its a better bin, but so far this is where im at, im pretty happy with the results TBH, voltages arnt too bad, vSOC is a very strange one, any less than im running now and I get errors, any more and I get lockups in windows, I couldnt care less about karhu, I use memtest pro and TM5, TM5 is probably one of the best ive used, it picks up errors very quickly, Karhu can get to 50k (12 hours) and then pick up 1 error.
This is the G.Skill CL26 6000 1.45v kit, currently im sort of testing RAM and curves, but been on and off for days getting it stable, loads of tests to run yet.
Hello all. Just switched over to a 9950x3d from intel as that will upgrade the kid's pc with that. Using x870e Hero on most recent bios I'm getting 119sp with the higher values coming from 8-15 cores. Should I be concerned it's a bad bin as any other I've seen are 120-121 or does sp have a lesser impact compared to the Intel lot. Thanks
That's a very respectable speed for ramThanks for the reply. I will check after work but I'm sure the cores are consistent. It's also good to know about the memory so similar with intel. I don't have any expo ram but got mine to 6000 28 last night so checking on stability today
