Fosi Audio has a new DAC/Pre/HPamp in compact form factor coming this month, actually looks cool and it has XLR output at the back, with 12v trigger in AND out, Fiio are you taking notes?!
Fosi Audio ZH3 All-in-One Desktop HiFi DAC/Headphone Amp/Preamp
Fosi Audio ZH3 DAC/Amp/Preamp - Provides versatile interfaces for headphones and active speakers. Easily switch outputs and control your desktop HiFi.fosiaudio.com
Nice that it has XLR out, RCA out AND RCA input. That's very useful.
One question; this new Fosi box lists it's spec as XMOS XU316+AKM4493SEQ+ OPA1612 x 4 (Fosi K7 uses the same AKM chip, but slightly lower spec I assume; XMOS XU208+AKM4493SEQ+QCC 3031+TPA6120). But the Fiio K7 uses 2 x AKM 4493SEQ + THX AAA 788+ chipset. I assume the use of dual AKM chips by Fiio (something the K15 does too) isn't for balanced, but just a design choice to allow for more power, lower distortion, or some other benefit?
Must be for controlling noise/distortion etc as regardless they are all fully balanced architecture
As an aside though "burn-in" shouldn't really be a thing with opamps - I have a lot of OPA1612s from my DIY amp building projects and I can instantly tell the difference between the one which are fresh out the box and those that have been used previously - they have a slight bright kind of artificial sound out the box which goes away with around 50-100 hours of use after which they sound much more neutral. Though that may change somewhat depending on the rest of the circuitry and/or whether there is any "burn-in" from the factory. One of my favourite opamps out of the ones I use.
"...the precision of overall stereo image is not there, so that is understandable for this price point, the sound is more forward in mid range and upper mid range area that is totally noticeable"
With the DX5 II and HE6 SE2 I'm hearing instruments in songs I never knew existed before, I'm still not too deep in the rabbit hole but for now it's been a great upgrade for me.
I wonder if Mariah Carey will sound any different, not long to find out....
Furthermore, the internal power supply is meticulously crafted. The system utilizes 18 low-noise LDO precision voltage regulator ICs and five DC-DC converters, providing multiple professional power paths and robust audio output. Selected silk film ELNA RA3 series audio capacitors and dedicated audio-specific tantalum electrolytic capacitors provide a pure, stable power supply for a warm, natural sound.
Thats a lotta juice into those cans
Interesting, will check it outI would recommend trying the grill mod if you haven't already. Cleans up the sound even further, its not a huge difference but it is noticeable.
