I wonder how much your ram might be holding you back. 3200Mhz CL22 seems slow.
Everything else looks ok. CPU might be considered to be a touch on the warm side considering the low usage but it's far from throttling so nothing to worry about.
Is Cinebench like Cinnabon? Run cinebench while running a specific game? I have a wide selection.The 3D Mark score is alright, but a little lower than I'd expect.
Can't see any other obvious issues, but your CPU's power usage is low, assuming you were running the sensor during gaming load?
Can you run Cinebench?
I can't tell. Were you running anything demanding like a game alongside the hwinfo sensor tab?I have took the glass panel off the side of my case and replaced it with the mesh one to see if that helps a wee bit with the cooling, but maybe getting a decent cpu cooler to help with the cooling down of the CPU?
No, Cinebench is like 3D Mark, but for CPUs. Don't run it with anything else.Is Cinebench like Cinnabon? Run cinebench while running a specific game? I have a wide selection.
My comment on CPU temp was based on this 3DMark graph. During the graphics test his CPU usage was sitting in the 10~20% area with temperatures in the high 70s or low 80s.I can't tell. Were you running anything demanding like a game alongside the hwinfo sensor tab?
They're not terrible, but they do seem low.https://imgur.com/FSmrEY7
https://imgur.com/rYT1DjA
This is the results of the run of Cinebench test
The power numbers were cropped from your screenshots, so I couldn't see them. It does note that the power limit was reached, though that's not necessarily a problem.Do these power and test images appear ok?
The settings used on my 12gb 3060 and 16gb 5060ti were exactly the same, did not turn anything extra on/off when trying the different games.Should there be a big difference?
Did you have an the same features turned on?
