Hello people.
I finally took the plunge and bought a Legion Go yesterday a certified refurbished one from currys ebay for £399 thought the price was ok and others reporting it was pristine when it arrived and im hoping for the same.
i knows its two years since launch but does anybody have any advice on what i should and shouldn't change about it, software or apps that are a must?
Watched a fair few reviews after i purchased and looked to have a few issues at launch also, track pad issues and right clicking were these ever fixed?
Does it run its own software or is it just really a laptop in handheld format? runs regular windows? or a tone down version?
Hope to get some help
I bought one for the Mrs on December 2023 for xmas present.
I also read a lot of reddit posts, Legion Go official posts etc.
I will write some thoughts and tips, I can write a whole thesis about this but I will try to make this short.
In my view it is basically a windows laptop with an 8.8 inch screen and detouchable controllers ala Switch 1. You can put SteamOS to it, though I haven't tried it because we have a lot of windows games on various shops (Steam, Epic, GOG, Uplay, Gamepass).
When you turn it on the first time it even does the windows 11 installation steps with all the crappy apps MS wants you to install. It took away from being a gaming console to be honest.
To me it was a bog standard win11 experience and thats how we treat it.
I uninstalled anything we werent going to use on this device like MSTeams, excel and quite a few more bloat. There is a guide on reddit I think on how to debloat it better but never bothered.
They do have the Legion Space app which should have shortcuts for your games/ gamestores but has also its own recommendations and prices. I only use this app when i want to setup the controller profiles and another useful setting is to not charge the device above 80 when plugged since the mrs plays on the sofa plugged in all the time anyway. It is assigned to the left controller top button to open the app.
Same on the right controller top button is a side overlay that pops up with the quick settings for performance mode, efficiency, balance on gpu and cpu, resolutions brightness fan curves etc, that i use constantly. This and especially the Legion Space app can be a bit slow in turning on though but overall i find this quite useful.
Also there are useful shortcuts with the top buttons (left button and one of the right gamepad buttons brings the keyboard up, or the task manager etc).
Mrs loves the detouchable controller, uses it to play games likes Sims without needing to bring a mouse.
One major tip for you, go into the bios settings and set the Vram to 6GB ram. By default i think its 3 and its not enough. They later added an Auto mode but i think people reported issues with that.
You could set it to 8GB but then you might be running out of memory - remember this is shared ram and takes from your 16GB ram that the system has overall (I just wish they had released this device with more ram but heyho). Maybe a good debload of windows will save you some ram.
Another tip, a lot of people us included complained about the sound of the device. It is really tiny and doesn't help that they are top firing speakers. If you search on reddit there are some settings you can do to the Equilizer and makes it way better.
It wont be like front firing speakers but will sound way better than factory.
SSD i have been wanting to change for quite some time but was waiting in case we sold this to get the Legion Go 2 that has full support for 2242 and 2280 ssds. Plus i noticed the mrs plays one or max 2 games at a time so the 512 is ok - bought also a 1tb micro sd Lexar A2 card which helped.
But in case you want to change, it supports 2242 ssds. You can get a 2230 (smaller) and make sure you get the little extender in order for you to be able to screw it down. Do not buy the adapter that plugs on the nvme slot and then plug your ssd to it people have had issues with speeds not being the advertised speeds etc.
Also it supposedly cannot take 2 sided 2242 ssds because under the ssd is the wifi antena and some people have crashed it a bit using a very nicely priced KingSpec 2tb 2242 ssd. I am not sure if its true or not so i didnt bother getting one although at some point it was really tempting at £90.
I think the Corsair MP600 Micro is a really fast ssd (not sure if double sided or not) people have used this one, its just a tad expensive at £170 i think but then its the only Gen4 from a reputable brand atm as far as i know.
The screen is gorgeous on this device. I can't believe an IPS display looks this nice. I never bothered with setting it to 60hz, in fact some games that run at 40fps ish i never noticed stutter (maybe helps that it was set at 144). And being a 1600p means you can drop to 800 and not have horrible interpolation especially if you use integer scaling.
We personally play at 1200p to get smoothness but also good eye candy, i cannot unsee how meh games look at 800 generally speaking. I will always start a game, put the settings i want to see and see if it runs at 1600p decent. If not then we drop to 1200p.
One negative of the screen and possibly extends to some problems this device has, they used a tablet panel which is on the portrait orientation, hence also why 1600p.
They did set it to default at landscape so you should not see it often if at all but you will spot the odd weirdness happening when you swap resolutions.
When i plug it to my tv and try to extend monitor etc sometimes the Lenovo monitor will be in portrait, and the tv landscape but for some reason will make Netflix etc feel like they drop frames, if only shown on tv. Problem dissapears if i just extend and use both screens and also the Lego monitor returns to landscape.
Also the fact that it has a portrait native screen means that Lenovo has to make drivers for the GPU. So you will see AMD releasing drivers for the 780m gpu (which essentially the Z1e has) but Lenovo has to go and make their version for the Lego to properly work. And that means that Lenovo are really really slow in releasing drivers.
There was a point where we waited 8 months. New Legion Go 2 gets its drivers directly from AMD supposedly for the chip because its a landscape oriented monitor.
We had a small issue where I had to use the warranty for ours, the controllers were wobbling a bit especially the right one. The mrs didnt mind but it bothered me.
There is a small issue with the rails that technically if you screw them a bit better then it solves it. I sent the whole device to Lenovo, came back supposedly fixed and they did nothing, issue was still there.
Second call i asked them to send me new rails and i would do it, they accepted and sent me the parts. Now it is rock solid i cant believe how much better it is now. I think this issue was with the early release models and was rectified later from the factory.
I think for £399 its a really good device. Especially since the Lego 2 with the Z2extreme processor starts at £999 with 512gb.
Feel free to ask me anything, I am no guru but i have spent quite some time tinkering with the device and every game the mrs asks to play i go and try to find the best settings for it.
