I guess if you follow a walkthru & someone holds your hand you run everywhere & gives you every single solution to all the puzzles you can speed run itSteam reviews says 3 hours lolk
I guess if you follow a walkthru & someone holds your hand you run everywhere & gives you every single solution to all the puzzles you can speed run it![]()
Those bugs really took some of the fun out of the game ... and subsequent patches didn't fix the problem. Until they do that the DLC is a pass from me.Achievement for all the notes & photos is buggedcommon issue...they hid some new unlisted stuff in the main game in the Vatican level.......lots of stuff does not register properly. Until they fix that do not be like me waste a good few hours mopping up
Good luck with that ... some of them can be bugged and prevent you from doing a 100% completion.Now just need to go back and find any missing relics etc and then I start the DLC.
The autumn steam sale is on the 29th September, may be a discount, currently cheapest is loaded (CdKeys)This game looks so good visually,
Is there any deals to be had on it? Cant seem to find it any cheaper than Steam, But £60 for the base game with no dlc is a bit off putting!
Of course it is listed in "Other" places legitimately but then says non redeemable in the United Kingdom
I guess its going to be one of those "Wait for Winter sales"!
Found my own fix for it have all achievements now! The thing you have to do is revisit a room in the Vatican level (near some scaffolding you climb up) several times until it shows the missing notes plus take a photo of the plaza! none of this is on the map BTW and the count for notes is wrong it ways you need 60 notes you actually need 61! I have 58/60 but all achievements now!Those bugs really took some of the fun out of the game ... and subsequent patches didn't fix the problem. Until they do that the DLC is a pass from me.
Gamepass tells me I spent about 82.9 hoursI played through the DLC over the weekend and was done in under 4 hours without a guide. If you don't already own it via the deluxe edition, don't go spending money on it. It's not just length that's the issue, but there's also a quality problem.
The DLC condenses the weakest bits of the base game. There's lots of tedious ledge-jumping in underground tombs (including a couple of badly signposted bits where I was left wandering around trying to spot the next interaction prompt). The boring boat stuff makes a return. Some of the puzzles are ok, but the hardest of them is essentially a battle with the UI while under time pressure. There's no real "immersive sim" stuff and there are no big action set-pieces.
The new Nvidia hair is very pretty, though.
That method doesn't always work, unfortunately.Found my own fix for it have all achievements now! The thing you have to do is revisit a room in the Vatican level (near some scaffolding you climb up) several times until it shows the missing notes plus take a photo of the plaza! none of this is on the map BTW and the count for notes is wrong it ways you need 60 notes you actually need 61! I have 58/60 but all achievements now!
The high brightness of the HUD with this is what puts me off the most, the fear of burn in is real!Nah he's content with RTX HDR, and so am I tbh in most things where the FPS hit can be absorbed
You have a 5090, which game can it not be absorbed in ffs![]()
You have to revisit that location several times the little room after the scaffold climb...then eventually the missing notes just magically appear! Also in the base game some new items appear but are not obvious as the map is glitchy keeping travelling to & from Rome & The Vatican eventually they appeared for me after I had given up all hope of getting 100%That method doesn't always work, unfortunately.
