Ok.
So the so called “UAP department” is agreed as “real”.
Not sure about the rest, but what does that get us?
You’re claiming this is all “real” how are you coming to that conclusion?
What substantive evidence have you seen that can back up the claim that you make, that this is all real?
Well yes one such example the Investigative journalist found some of the many millions in “black money” that funded some of the UAP departments which they found by following the money paper trails which reviled some of those classified UAP departments as real. You do member that right? We have been over it enough times with links.
“You’re claiming this is all “real” how are you coming to that conclusion?”
How many times does this have to be explained. One case is the IC IG investigation division are responsible for investigation, allegations within the Intelligence community. They specialise in classified data.
The IC IG went in an interviewed the whistle-blowers, interviewed all their colleagues, spoke to everyone in there department, spoke to there line manager, looked at all the evidence did a full proper investigation and put out official statements which you have seen multiple times. Even the Inspector General himself signed a document backing up the whistle-blowers.
Not only did this prove credibly to the whistle-blowers but if as you say, the usual suspect where behind this, none of that would have been possible and the IC IG would have come back and said this is just a few grifters with no evidence. The IC IG don’t mess around, you don’t mess around with the IC IG. The usually suspects cannot possibly infiltrate the IC IG and fake all those reports.
There are loads of documents like this.
https://www.disclosurediaries.com/c...David-Grusch-PPD-19-Procedural-Filing--1-.pdf
Paraphrasing
“He is currently clear at TS/SCI level by the NGA and serves at the agency UAP analyses division.” You know the UAP division/department you deny is real but is there in official paperwork to show its real.
Also from the official government documentation. Mr Grush served a fully cleared member of the
US UAP Task Force.
Hence the UAP Task force and division is real. The whistle-blowers inside those departments are real and they have/had security clearance to work in them and access the files.
They are not faking it by pretending to work in a fake department under the instructions of your usual suspects. Above isn't even the only official paperwork. There is loads more, many of which has been shown to you over the past years.
Your the one denying these whistle-blowers are real whistle-blowers and denying they worked where the evdeince shows they worked. So how are the whistle-blowers not real then as you keep saying? Do you think they faked working at the UAP taskforce and somehow faked all that paperwork and investigation files?
So where is the substantive evidence for your conspiracy theory?
