Any tips for repairing a Nintendo switch where the joycons randomly disconnect/turn off when they're in handheld mode? I can't see anything wrong with the joycons or sides of the switch, but you slot them in, start playing and at some point one of the joycons (normally the right one) will just switch off at random. Tried other joycons from a perfectly working switch and the same thing happens, which suggests it's the main switch hardware itself rather than the joycons at fault.
Also, one screw on the back panel is completely rounded off. Not sure there's much i can do without a tiny diamond drill bit to remove it? as it's also potentially overheating so i need to clean it out somehow.
