The writing is definitely still Borderlands, especially on some of the side quests, its just that the writing is BL2 (which is a positive) rather than BL3 (which would be a negative)For all that I thought the writing had been sanded down a bit, I found a quest involving threshers last night that was as screwed up as anything in BL2. I approve!
I guess it's like they always teach in creative writing classes: when in doubt, go back to the bestiality well.
Anyone playing on a similar rig to mine 7800X3D with a rtx 4070.
Wondering how it will perform at 1440P.
I dont mind DLSS + Framegem once its a smooth experience.
Oh well, looks like I'm going to have to wait for a driver update or a patch. Can't play for long before a crash.
Thought I'd narrowed the issue down to the upscaling method as I got a bit of time out of it with that disabled but I'm not back to the constant crashing.
Running on a 5090 for what it's worth.
Yep.You on the latest NV driver, and installed today's patch?
Seems 50 series are the RTX cards having the most issues in this game![]()
ZERO issues on my end, 5070ti.Seems 50 series are the RTX cards having the most issues in this game![]()
I saw that the HWUB video they totally left out 4K upscaled performance yet had it for lower resolutions, wonder why that was....
NopeDid they give figures for the B580?
Not on my 5070TI, not one single issue yet /touchwoodSeems 50 series are the RTX cards having the most issues in this game![]()
I'm very similar.
BL2/BL4 very much equal at the moment,
BL1
BL3
Pre-Sequal being the runt of the litter as far as I'm concerned. Didnt click with this one, I found the overwhelming Aussy influence to be a bit grating.
Havnt played Wonderlands so cant speak for that.
Just to add to this, I turned on frame generation and now have solid smooth 60fps. Control does feel a smidgin laggy but that could just be me.Bought and installed BL4 today with a slight twist. I use Batocera Linux for my gaming PC. The important hardware stats are a Ryzen 5700 CPU and a 16Gb 6800XT GPU. I’ve completed the intro mission which was fun enough. Playing at 1440p with a lot of the graphic options at high or very high, the FPS was dipping down the low 40s at times. I’ll do a bit of fine tuning but don’t really expect the FPS to change much. Can’t say the graphic fidelity is much cop given the hardware requirements but the gameplay seems fun enough for me to see past that.
