Recommend air cooler to fit?
28 Jan 2011
Hey guys,
I think I might run into a problem here, I will be building my new once the rest of the parts arrive today / tomorrow..
Now, my problem is the cooler for the CPU. The board I am getting is the Gigabyte B850 Aorus Elite WiFi 7..
As the NVMe drive is below the GPU PCIe slot, the GPU is close to the CPU and I’m not 100% sure the 120 Thermalright Peerless Assassin will fit with enough clearance?
So I was looking at a 92mm fan setup, can someone recommend me a good one to cool a 9800X3D?
Or if the P Assassin will fit that configuration?
Cheers.
I usually suggest the freezer 36 for more compact builds, but I don't think either of those coolers have any compatibility guides of the type Noctua provide.
Thanks, still might be a touch to big?
Ordered a Peerless Assassin 90 SE. £16 and I have another fan (same model from Thermalright) and should be here tomorrow as a backup in case the 120 variant doesn’t fit!
Why would the 120 be too big?
It's a pretty standard configuration.
I am just concerned with the PCIe slot being close to the CPU and having interference.
could be worthwhile getting second hand one so if doesn't fit just sell it off same price you paid for it
Thanks but the price I paid was peanuts anyway so will hold onto if there is an incompatibility.
Quick CPU question, to assist with cooling, does ECO mode set in the BIOS lose a lot of performance as it does (in my past experience) help a lot with thermals.
The gaming power use is pretty low anyway, though it'll depend on the games/settings/res and your graphics card. Heavily multithreaded stuff it would have a bigger performance impact.
Yeah, solely for gaming, looking at medium to high detail at 1440p. And the gpu is a 5070ti
Don't forget you can turn the Peerless Assassin around 180 degrees, to make it offset or not offset, so either way, you'll be fine :)
If you're unhappy, simply flip it around and have a bit more room :) both orientations still clear massive VRM coolers ;) I'm surprised that no-ones mentioned this?
But here's some tighter fit clearance pictures, that show that it'll still fit regardless of being super tight - but your board looks like it'll have more room that these, but either way they all still fit
iu
iu
iu
Here's mine on a MATX b550 board with an rx6800xt
Can you please do some cable management, that is rather offensive :D
You haven't even zip tied your PSU cables, nor cut the ends off that ziptie you lazy git :P
What's going on with the rear exhaust wiring and the 2-into-1 cable for your Thermalright fans? :P They're just blowing in the wind, doing what they like :cry:
First the thermal paste abuse, and now this :P
I was of the understanding, that this was a bannable offense? Right @Armageus :D
I can't even be bothered to swap my phanteks 850 into my intel pc which has an rm750
:D
:D
What's that got to do with tidying up cable management with zipties :confused: :D
But then you did get bored attempting it before to the point you didn't even clip the end off that ziptie:P
It doesn't matter to me... Function over form.
I'm Usualy looking at my screen not peering into my case. There's nothing loose so meh!
