They have always graded the AirPods I've traded in as "B" because of the hairline scratches on the case. Visible to no-one except them it seems. lolJust went into CEX in town and handed over my Pro 2s and everything was perfect, they then said the brand new apple cable was not the correct one as it wasn't looped to fit in the bottom of the box so I got £96 instead of £114 so £18 less as they classed it as a "B" grade item due to a brand new Apple cable.... Meh!
At least my 3s are arriving Friday![]()
For me the most important feature is ANC so not too worried about sound quality as long as it is acceptable.Seen the reviews, looks like a decent upgrade in most area's EXCEPT sound quality. Some people are saying its the same and I seen a couple saying its actually worse. Blindfolded tests had the APP2's being picked more than the APP3
In which case it seems worthwhile the upgrade. I suppose if you have the 2's then it might not be as worth it, but any other model then sure.For me the most important feature is ANC so not too worried about sound quality as long as it is acceptable.
My 2's gave up the ghost about three weeks ago so the timing has been pretty much perfect.In which case it seems worthwhile the upgrade. I suppose if you have the 2's then it might not be as worth it, but any other model then sure.
I personally probably wont be upgrading until the 4's or maybe even the 5's
How Lucky! I bought the 2's a few years after release so they're still going great but I know some of the early user's report a lot of battery issues where the charge just doesnt last anywhere near as long as it used toMy 2's gave up the ghost about three weeks ago so the timing has been pretty much perfect.
Hmm. I've never had a case for AirPods. Might look into one if they look decent.Ordered my pro 3, arriving between 30th September and 7th October. Hopefully dbrand case arrives before then!
I tried the DBrand but was like a protective sticky film which drove me up the wall! Unless it’s the hard case?Ordered my pro 3, arriving between 30th September and 7th October. Hopefully dbrand case arrives before then!
Yeah I've gone for the Grip case. I use to have a Grip case for my iPhone 15 Pro Max but now use Ghost Case 2.0. I also have a Killswitch for my Steam Deck. Yeah I'm kinda a big fanI tried the DBrand but was like a protective sticky film which drove me up the wall! Unless it’s the hard case?
No I’m the same, find a brand (no pun intended!) they are amazing productsYeah I've gone for the Grip case. I use to have a Grip case for my iPhone 15 Pro Max but now use Ghost Case 2.0. I also have a Killswitch for my Steam Deck. Yeah I'm kinda a big fan![]()
