bit like the wife![]()
Tell me you haven't had a lay recently without telling me
tbh a lot of these testers just throw up standard faults that may or may not be there. i had snap on/bosch/and launch to name a few and often got different faults on same vehicle , if it drives ok and doesn't flag a warning light as others have said just drive it . it will soon tell you if it needs attention....bit like the wife![]()
ISTA works on the F series for sure. It is the only software that should be trusted with a high degree of certainty, in my opinion. The likes of Carly and BimmerLink often get things wrong when it comes to reading fault codes or warnings. They are just reverse engineered products after all.Yeah to be honest no one here is able to help with such ‘problems’. Try bmw specific places.
Plus Carly isn’t that good. I had stuff appearing saying wrong wheel sensors etc and ISTA didn’t have the same results on my E series. Don’t think ista works on yours ?
Any sensors flagging something won’t be a problem enough alone as they rely on others. But just replace them for your OCD.
Thank you! It seems to have thankfully resolved itself. Not seen that happen before (I was a bit worried). I did have software update yesterday so perhaps just a glitch. I've just returned home and on starting the car for the return journey, it disappeared.Hi,
Usually does this when in places with no normal speed limit signs/location that doesn't have a speed limit set on the map data (car parks etc).
Additionally, a quick google:
If your BMW's iDrive system is showing "LIMIT" instead of the actual speed limit, it likely means the Speed Limit Info system is on but not detecting a limit. To resolve this, update your navigation maps, perform a soft iDrive reset (hold the volume knob for 20-30 seconds until the screen restarts), and check your iDrive settings for Driver Assistance > Driving > Speed Limit Assist to ensure it's set to display current speed limits or anticipation, not turned off
ISTA works all the way up to the G8X, latest Rolls Royce, MiniISTA works on the F series for sure.
Avanti, Road master, singleng or some such tyres I'm sure unless you're very specific.Well it's been a few years since I sold my 640D but after a happy interval driving an Audi it looks like I'm back in the Bimmer family. Put a deposit down on a M340d Touring. The garage are putting it through a fresh MOT and 4 new boots and all being well I should have it by the end of the week. It should be quite the change from driving a 2WD 200hp A6 Avant.
Private sale? Or to the trade?Well the BMW has gone! A really, really good car, but just not a convertible. Would have loved to keep it as a daily but couldn't justify having 3 cars.
Private. Got asking price for it, so £22,495 less a wheel refurb.Private sale? Or to the trade?
Nice! TBF your 340i was mint so that's a result.Private. Got asking price for it, so £22,495 less a wheel refurb.
Did you get a quote from motormoolah in the end? If you did, I'm just curious what they offered you lol
Wow only 17! That's insane for a mint 340iYeah I did, was around 17 I think. Lowest I had was 13 from WBAC.
Ikr! Glad I held outWow only 17! That's insane for a mint 340i
