Fire Thread! - Stoves, Wood, Axes, Chainsaws
"There not proper ones"
Ash vacuum will usually have a secondary hepa filter of 99.97% efficiency. Not sure how this isn't proper for the job it's designed to do.
The sweep I use hasn't put his price up and was £60 -After cleaning mine all my life I will be using a sweep till I pop my clogs. So worth the money as against all the mess it used to make when I did it.
Had 1cbm of logs yesterday - Seems they are reduced to 0.08cbm as there didn't seem to be as big a pile as it used to be.
Woodburning is getting very expensive these days unless you can get your own uncut trees and log them yourself.
I wish I had a bandwagon I could jump on.
I don't know about you but I'd rather not breath in soot.
Then why are you just using an upgraded filter on your Asda vacuum? Changing a filter on a household vacuum will not make it class M. It will need 3 filters, an indicator for when it is full and a function to shake the filters after use. Yours will just filter it for a while then block up.
But I digress, an ash vacuum with a primary filter and secondary hepa filter will do the job for £40, and no, you won't be breathing in soot.
I bought an ash vacuum last year. It has 2 filters, one of them being a hepa filter. No soot comes out of it.
It does get blocked due to chunks which is annoying. I almost prefer my old method of pan and newspaper.
Small crate of kiln dried ash arrived today. Should keep us going over winter. Mostly only use it evenings and weekends.
AP1GczN0XYOq6MbjwoqfKtrxUtd0zVTTU-ifG3Q4cpyj-1Agk-jklZgkOLMLq4ZRHbBk0YV_amvjduJismoccvfp43z7So2mijyVoCm39eE0zQf9ROrAXBFLvh2HUpIK_2FmkQ-e8XS8-XN6DaniK0HJZLA_=w1693-h1270-s-no-gm
How much did those crates set you back?
£379 incl Pallet Force delivery.
Lit the wood burner tonight - Better now than when you need it and find it has a problem.
Going really well after chimney clean and some thin hardwood logs.
Ronnie is smiling. He loves that heat.
This has reminded my that I have a load of old, unpainted pallets that need to meet my Parkside skillsaw and become kindling.
Ah, I have a father in law with far too much time on his hands, who just appears at ours with bags of kindling every so often. Always a winner.
Just ordered a small coalstore to store it in.
Fire’s lit, don’t give a ****.
Full disclosure, it’s 14° and damp outside, so today’s been a perfect day to give both the wood burner and my gas CH as short burn to check everything’s behaving itself.
Will visit my wood supplier shortly to see what oak split and cut to 33cm cost this year.
