Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
As a Chinese...I am not sure what the think from the past few posts lol
I use the same bowl I boil it in, and scrub between my palm and fingers a few times until the water is mostly clear. It will never get to bottled water clear. This is perhaps a habit as well as a tradition rather than really required with modern factory-packed rice but habit can't be broken and it doesn't make it worse so i keep at it. Used to use this step to check the grain for any bits of impurities like dirt or random things.
Then eyeball the water, some Chinese people will tell you to do it up to the first knuckle....I have never done that, we all have different size hands. I have done it enough that I know how much water to use, regardless the amount of rice, by eye ball. I know it doesn't help, but do it once, if it's too mushy then next time use less water, trial by error. Eventually, you will know.
The key really is to leave it at least 10 mins after the switch flicked at the end, even with the most expensive cooker.
