If you select the option to “inspect” the item you can then hover over each icon with your mouse pointer and that will tell you what they are ( usually skills )
Seems to provide a "Break Free" pack which contains some cosmetics and a lvl 25 legendary energy shield.any one else zoomed into the consoles with what looks like green code text?
edit: another key? JS63J-JSCWJ-CFTBW-3TJ3J-WJS5R
theres shenanigans if u zoom into the consoles with green text that look like codingSeems to provide a "Break Free" pack which contains some cosmetics and a lvl 25 legendary energy shield.
After you mentioned it I had a look using the zoom on my sniper rifle ... it's not just gibberishtheres shenanigans if u zoom into the consoles with green text that look like coding![]()
Yup, that's the way I'm doing it, too. At this rate I'm going to get 100+ hrs out of the game. Currently going through a series of side missions involving Topper the legless Scottish Ripper.I think its going to be quite some time before we finish the main story, we're trying to 100% each area as we go (so do all side quests, uncover all ? Locations, get all collectibles, do all POI in each area, before we move onto the next area), so as a result, we're 22 hours played and only just reached the town where you get the hoverbike thing. So barely 10% of the main story done yet![]()
No. But before each crash ( I've had 7 now ) performance begins to feel sluggish and I note that my controller / mouse inputs start ghosting. Feels like a memory leak of some sorts. But then I can have periods where I play for a couple of hours with no issues.Did anybody experience any issues last night? i was playing around 7pm was running smooth around 300fps , by 8pm it got extremely sluggish was struggling to get 60 fps. Also upon checking settings seemed like the game had tried to make some adjustments and dropped the quality really low as i play on badass at 1440p.
I closed the game and reopened changed the settings again and was fine was very odd.
I did enter a new area i had not previously been too at the time could be that? bug?
Some of the side quests are SO good, plus you even get quite a few references to previous BL titles , characters and events in some of the side missionsYup, that's the way I'm doing it, too. At this rate I'm going to get 100+ hrs out of the game. Currently going through a series of side missions involving Topper the legless Scottish Ripper.
I think we've just been lucky, still none of us has had a crash yet. Mind you, I'm nearly always lucky with these sorts of things, almost never get performance issues or crashes on games. I must have fallen into the gamers lucky potion cauldron as a babyNo. But before each crash ( I've had 7 now ) performance begins to feel sluggish and I note that my controller / mouse inputs start ghosting. Feels like a memory leak of some sorts. But then I can have periods where I play for a couple of hours with no issues.
