I seriously doubt it.FFS bought a UNAS Pro 2 weeks ago. Been looking at a UNVR and ditching Hikvision. Can the UNAS pro be turned into a UNVR pro so I can get the New 8 drive UNAS and not feel so much pain
You'd need to use different External ports.Dumb question. I'm trying to add SSL/HTTPS to accessing my UGREEN NAS (browser) but I need to make a port forward rule in Unifi for 443 and 80. However I already have rules for this for my Emby server, and that was an effort to do the same thing so I don't really want to tinker with the Emby stuff again. Any suggestions, can you have more than one instance for the same port or can I use alternative ports for the UGREEN rule?
You shouldn't really be exposing ports to the internet.Dumb question. I'm trying to add SSL/HTTPS to accessing my UGREEN NAS (browser) but I need to make a port forward rule in Unifi for 443 and 80. However I already have rules for this for my Emby server, and that was an effort to do the same thing so I don't really want to tinker with the Emby stuff again. Any suggestions, can you have more than one instance for the same port or can I use alternative ports for the UGREEN rule?
Thank you, as part of the guide, you have to install Nginx which I have. It isn't working as per guide but I think that's because it's set up for 443/80 and I don't have a port forwarding sorted (step 8). Though I notice for step 12, it's port 9999.You'd need to use different External ports.
The alternative is to use a reverse proxy (e.g. Traefik or Nginx), expose that to the internet, and then have that deal with the different services. (Or use a VPN to access your network and then access them as if you were local)
Thanks, it's not want for trying. I'm just not good at this kind of stuff, have tried a bunch of guides but usually something doesn't match up/goes wrong (Caddy reverse proxy for Emby and tailscale VPN for immich were successes). Back to the drawing board for this.You shouldn't really be exposing ports to the internet.
As above, use a reverse proxy or VPN. Or you can use a Cloudflare Tunnel which is free.
I would look at Cloudflare tunnels. Very basic steps:Thank you, as part of the guide, you have to install Nginx which I have. It isn't working as per guide but I think that's because it's set up for 443/80 and I don't have a port forwarding sorted (step 8). Though I notice for step 12, it's port 9999.
Thank you, am I remembering right there may be an issue with Cloudflare's TOS and the likes of Plex/Emby streaming?I use Cloudflare Tunnel for Plex remote access, it's set and forget. Just disable caching as the blog I linked to mentions.
For stuff I don't want to expose, I run it behind an nginx proxy and I have a wildcard cert for my domain (which it automatically renews using a CF API token). I then have service1.domain.name, service2.domain.name etc pointing to all my own internal applications.
The blog I linked to explains it well. Just disable caching as per the article and there's no issue.Thank you, am I remembering right there may be an issue with Cloudflare's TOS and the likes of Plex/Emby streaming?
Mines?Point me in the direction of one, 8 bay rack mount, 10gbe, low power.
But no, I also want simplicity. These will just work.
Apparently they are hardware identical apart from the UNAS has 8gb ram as opposed to 4gb. I'll grab the UNVR and see what I can get for the UNAS Pro. Although its probably not worth the "upgrade"Thanks for taking one for the team! I don't think they can be used as NVR, as much as that makes sense. I think all you could do is manually archive from Protect to the NAS.
The desktop NAS look good value, but I have everything in a rack so the 1U version is what I would like. Just have to put some money aside as I also want to start using some newer hard drives. Current HDDs are 10 years old I think. I do have on-site and off-site backups but feeling like that's borrowed time on the current NAS (a self-built ZFS pool on a Ubuntu machine in a 2U case!).
