Been running Fedora for a few years on a Minisforum UM480 XT which I've decided to move out of my main work space. More necessity, but things like Microsoft Office and Roblox (daughters plays it) means I just can't ditch Windows 11 right now. And I've basically got annoyed at running two separate PCs. I could run a separate hard drive for a Linux installation, but that has it own issues.
So I've decided to repurpose the Minisforum PC as a Steam Machine in the lounge. Bazzite felt like the obvious choice with everything pre-installed and a Fedora base I'm familiar with. But I thought I'd give Steam OS a go. I've seen a few videos of people trying Steam OS and aware of the limitations. And although this is fairly low powered; Ryzen 7 4800H CPU, Vega based GPU it coped very well with desktop tasks, 4K video and 'light gaming'. I think I installed Steam OS version 3.7.7 and it was quite slow to install (might be the old USB stick and the 3GB+ image) but with only a few options to select; timezone, Steam login etc.
However given the AMD base it's gone OK, so far. I played Brotato, Vampire Survivors, Balatro and Helltakers (lost a few hours testing these!) and all played well. There are a couple of issues; the frame-rate seemed to have been halved. My monitor is 165hz LG, but on the HDMI inputs is limited to 144hz. Normally under Fedora + Steam Brotato would run 130-144fps depending on how much is going on. It was running at 60-72fps so I assumed is being halved for some obvious reason. Also I had to use a stock Xbox One S controller as my Guilikit KK3 Max went crazy the minute you pressed the Xbox Guide button (on 2.4g wireless adapter, or directly over USB - need to try Bluetooth.). This might be a firmware issue but this controller was fine on Fedora. Also rumble worked on the controller test screen, but can't remember it in game.
At some point I'm going to move this over to the louge and continue testing the 4K TV and see how it goes.
