Tired of taking everything off my bike for plane trips, I bought the EasyFit version of the BikeBoxAlan that I currently have.
Check if you got a charger with this - I bought two and both were missing one!
If you mean charger cable, then, yes it did come with a USB-C cable.
do they use a standard usb charge socket? and is the dispensing mechanism noisy? would like one but that always puts me off them
See above.
I guess that depends on what you would class as noisy? as both that I have (different manufacturers) wouldn't cause ear damage, but at the same time are not silent.
They are great at keeping the grime away from whatever you would usually touch.
See above.
Ours had these weird circle adapters but it was from China so ended up having to order one! They are great though!
Not going to run out of wheel weights any time soon......100x60g strips of 4x10g & 4x5g! Also bought an IKI FoamPro 2+ and some foam to put in it. The foam sprayer has a schrader valve so I can pressurise it up using the airline instead of pumping it up like some sort of cavemen. Happy days. Means I don't have to get the full pressure washer out each time I want to give the bikes a once over, I can just grab the portable stuff (along with the rechargeable "pressure" washer) which is so much more convenient. Probably safer on the bikes as well, as the water pressure is much less.
Both come with transparent sticky wall pads and were purchased on Amazon.
Probably going to add another to the kitchen next.
Couple of these Zero In fly catchers:
Absolutely brilliant, wish I'd bought them at the start of the summer, we've had a nightmare with pest insects this year.
I need this so badly. For some reason where i live its like the m1 for flies even though theres no reason for there to be such a concentration of them. I hate then and i get minimum half a dozen a day that fly through the open windows that i end up killing
Also adding to the recent spending spree.
Couple pairs of sunglasses. When i sold my car back in the UK, i realised upon arriving in Spain that i'd left my really decent polarised sunglasses in the little glasses storage compartment in the roof. I've then got a pair of non polarised ray bans which are ok but not great in, especially in the low sun. I then bought some cheap polarised ones from Hawkers which aren't brilliant so have wanted a decent pair for a while.
Bike pair is a similar story. I bought some photochromic ones from a cycling brand called Siroko, but they're pretty rubbish when heading into the sun, especially the lower winter sun.
Also had sold my cheap Titan nailer/stapler in the UK before moving and have had a few times now wished i had one. Kept debating between air and 18v, but the 18v Einhell isn't brilliant and only takes <=50mm nails, and the Dewalt is crazy expensive. Ended up with this. Weirdly it has a removable built in pencil sharpener
Ha ha. Are you suggesting riding to the airport and strolling through security and onto the plane with the bike? Just pop it in the aisle? I'm not sure I could get away with that...
I think he means send it to hold naked, but if that was possible, carbon would be too fragile to do that.
I like the idea of taking my bike abroad by plane but struggle with the idea of spending a holiday amount on the box. How do you find taking something so big in the taxi to/from the airport?
My brother in law was doing Milan once a month for a bit. He just had a big cardboard box he packed it into each time under his arm!
