- 19 Dec 2010
- Berkshire
Cleaned my filthy exhaust tips, autosol works wonders !
Ordered some Cohline 2240 R9 compliant reinforced fuel line for the little car. It can take biofuels etc.
A while ago it started leaking after I changed the fuel filter, got trailered to the garage and they changed the fuel line completely (so this is about a year, possibly two old now). It started leaking again. The hose is disintegrating, removed the offending section but it seems that the piping they've used is disintegrating along its length so I'm wondering if they used cheap ***** fuel line that can't handle modern blends..
When that arrives my job will be to replace the entire section from the fuel sender to the fuel filter as I don't trust it one ounce.
What supplier did you get it from? I tried the Gates stuff and received a counterfeit product which failed in a dangerously short space of time. Replaced it with whatever ethanol resistant stuff Halfords carry and that was likely fake too because despite claiming to be ethanol resistant hose it started cracking in fairly short order as well.
This was a few years ago now but I did some research at the time and it seemed that fake fuel hose was pretty rife on the market.
In the end I gave up and got Codan J30R9 hose because I read it's what a lot of manufacturers put on new cars, and it's been perfect.
Gates along with most old school bearing and belt brands, aren't the quality, nor construction that they used to be, IIRC Gates along with most of the oldest standing names, have been bought out by China years ago, thus you recieve a brand name and nothing more than cheap Chinesium garbage.I tried the Gates stuff and received a counterfeit product which failed in a dangerously short space of time.
I bought a very expensive Bosch starter motor recently and it was all written in Chinese, which was very annoying - I get that they claim it's been through just as thorough of a QC and production as other factories, but in reality, Chinese made car parts tend to be awful and a con, even from a legitimate supplier - the rest of the time they're fake parts and even worse!
Some people claim, that it's as simple as not buying too cheap a part and choosing the middle ground etc with Chinese suppliers/parts, when in reality, they're all the same price at 3 different markups!
And new cars are boring. Imagine the free timeShimmed the kingpins, tightened the wheel bearings, adjusted the steering box, topped up the shock absorber oil.
Yep, bought from a legitimate place, I then looked online, and yep China knocks out most of their stuff nowWas it definitely a Bosch starter?
Bosch parts are some of the most counterfeited ones there are.
The injectors I bought for my E30 have a seal which has a QR code and a holographic portion, and an 18 character serial number, and instructions to check its legitimacy on a website before you break the seal.
Even "legitimate" parts suppliers end up with fake Bosch items in stock without knowing it. Its kind of nuts.
Honestly, is this what the main dealer experience has descended to in 2025?!
