You’re probably experiencing the shaders recompiling leave it 10-15mins to settle, otherwise clear the shader cache.Since the patch today the performance is terrible for me.
Never had an issue until the patch now it's a stuttery mess and looks like it's causing high temps on the cpu.
mine compiled shaders on booting up the game after patching then it came up compiling shaders on the first load screen in the game and been fine since.Weird that it's compiling shaders while playing, should be doing that at the start
It's possible that everyone needs to force the game to recompile by deleting the shader cache file
is there any point in keeping legendary items in my bank, eg can i break them up for materials or any thing later on?
Ive been hittting mute on the keyboard just before that annoying "gearbox" so thanks for this .Another useful command for the Steam launch options: -NoStartupMovies
It removes the annoying gearbox movies that play at launch and goes straight to the login screen
Aww I love the GEARBOX bitIve been hittting mute on the keyboard just before that annoying "gearbox" so thanks for this .
More than likely it's just the shaders compiling in the background, usually settles down after 10mins or so, although think Gearbox advise it can take up to 30mins. Saying that you might want to consider increasing your shader cache from default to 100GB, BL4 uses around 10GB overtime. Otherwise enjoy you're new PCI managed to remove the nvidia app yesterday and i also did the huge update.
I managed to succesfully implement the badass(ultra settings) and now its running like a bag of ***** ha
I dunno if its the game , the update or my new build which i thought was super duper and now its not
Still getting around 100-130 FPS but it just doesnt feel smooth at all now, even dropping it to high didnt really improve anything either.
please just tell me its the new update , im not upgrading again i only built this two weeks ago![]()
im not so sure if im running MFG i need to check that.Well I get about 65-80 fps on Badass settings on a 5090 so I don't know what 5070Ti you are running but it sounds pretty good....
I assume you are using MFG?
