Hi all got a random issue I would like your advice on. A few months ago I bought a Telecaster and a Blackstar ID amp. Honestly, it's been the best thing I've spent my money on in years; I have fell in love with playing the guitar again and can happily spend hours just learning things and jamming away. So first of all, a massive thanks to the advice from this form
Today I upgraded the amp to the ID Core X - I want something with more cutomizeable effects and and fx send/return for a loop pedal.
I get it home and it sounds great. But later in the day i notcie some clicking/static type noise coming from the amp when I strum the strings. I assume the amp is faulty, so I spend the next hour trying to confirm its deffo the amp before intedning to take it back tomorrow for a new one. I try different cables, plugging it into different power outlets, taking off my jumper, even different picks but to no avail - the clicking/static sound is still there.
I never got this problem with my previous amp so at this point i'm convinced its just bad luck and a faulty amp - no problem they'll sort it tomorrow.
Then i realise the noise isnt coming from when I pluck the strings but when i touch the pick gaurd with my finger. I run my finger acoss the pick guard wihout plucking the strings and recreate it. I pluck the strings without touching the pick gaurd and the noise dissapears.
So... not the amp! A little reasearch tells me pick gaurd stauc is a thing!
Is this something anyone else has had before? is there an easy way to get rid of it?
Again - any help or advice is hugely appreciated!
