Policy Based VPN coming in handy with the latest Imgur shenanigans.
Haha, I did this very thing today. imgur.com domain routed out via Windscribe.
I wonder how long before there's an 'OSA' list maintained on GitHub.Haha, I did this very thing today. imgur.com domain routed out via Windscribe.
Is there a guide for that online?Policy Based VPN coming in handy with the latest Imgur shenanigans.
Most likely. Generally just grab a config file from your chosen VPN provider, add it into UniFi in the VPN client section, then add policy based routes. In this case a domain one, pointing imgur.com to the VPN.Is there a guide for that online?
I have a config file from Nord, i just need to figure out how to route certain traffic through the VPN and not all.Most likely. Generally just grab a config file from your chosen VPN provider, add it into UniFi in the VPN client section, then add policy based routes. In this case a domain one, pointing imgur.com to the VPN.
Depending on the version you are on, something like Settings > Policy Engine > New Policy > Route > Call it whatever you want > Policy based and set the interface to VPN you configure > leave default apart from domain name > add in some domain.name > done. You can add more than one domain.I have a config file from Nord, i just need to figure out how to route certain traffic through the VPN and not all.
Cheers.Depending on the version you are on, something like Settings > Policy Engine > New Policy > Route > Call it whatever you want > Policy based and set the interface to VPN you configure > leave default apart from domain name > add in some domain.name > done. You can add more than one domain.
I should add that any domain name you add will be visible by Ubiquiti support staff if you open a case. edit I can't spell imgur.com, CBA changing the screenshot.
Am I right in thinking that this only works if DNS is managed by your Unifi router? And won’t work if you’re using an adblocker for exampleDepending on the version you are on, something like Settings > Policy Engine > New Policy > Route > Call it whatever you want > Policy based and set the interface to VPN you configure > leave default apart from domain name > add in some domain.name > done. You can add more than one domain.
Do Imgur have any legal entity that falls under the jurisdiction of UK law?Chaps, its worth pointing out the Imgur hasn't dropped the UK over the OSA, they have breached GDPR (Data Protection Act 2018) and decided to drop the UK over the ICO enforcing the breach of 7 year old legisaltion which applies EU wide.
I don’t know but it doesn’t really matter, GDPR applies globally, that was the whole point of it.Do Imgur have any legal entity that falls under the jurisdiction of UK law?
Yes & No...Am I right in thinking that this only works if DNS is managed by your Unifi router? And won’t work if you’re using an adblocker for example
You should be considering retiring the USG-3P as it's long EoL and not receiving any security updates. But yes, most FTTP has a ethernet cable from the ONT to the WAN on the Router.Currently with virgin media for broadband, FTTP has just been released in my area. Currently I have a USG-3P plugged into my VM router which is in modem only mode.
WOuld I connect my USG-3P directly into the ONT for the fibre, or would I have the same sort of setup as with virgin?
Thanks
Full fibre released, ie BT openreeach. So a provider using their network..Is it actual fibre or still via the coax copper into the home but high speed? Branding can sometimes be confusing, not sure how they are referring to it now.
If it’s Virgin via coax, then you’ll need to keep the VM hub in modem mode and connect that to any new router.
I have Virgin fibre direct into the home and they do not give an ONT but a crappy router (Hub 5x) that doesn’t support modem mode so if you want to run your own router you need to double NAT or get creative with replacing the Hub but I would say the latter is risky and experts only. Double NAT is what I do and it’s working ok, but it could be a dealbreaker depending on your uses.
What would you recommend @DIABLO
Thanks
