- 14 Apr 2014
- Hampshire
Has it been parked outside in the winter historically? It's quite unusual for the arms to fail at less than 10 years of age with more than just a bit of play.
Is the tailpipe clamp being referred to as the clamps for the exhaust tip? Those are just two basic clamps and easily replaced with Mikalor clamps. Chisel or grind the spot welds off the clamps, then replace with Mikalor clamps. It's a 30 minute job and the clamps aren't even a fiver. 560 seems a bit mental if that is what's being replaced.
The rest seems pretty standard if they are genuine Porsche parts. You could save some cost by finding the Porsche OEM and buying the part from there instead.
I think the dealer will scoff at the £5400 bill and want to look at other options. Are they a reputable dealer with a good rep?
I was told it was parked by one of the owners in a temperature controlled garage
Said owner also had a new Bose amp installed due to water damage so…
Not sure which clamp it is, but in my many years of experience, they don’t take the pee. They’d rather find cheaper alternatives.
I was already tempted to put the car under warranty and if they don’t use Porsche parts, it won’t be covered.
Most of the cost is parts, their labour is £125 + VAT which is good for down here.
BMW are £252!
