Did anyone get a bit travel sick driving their first EV?
Maybe I'm just getting used to it, but I've not had this with ice cars and when driving the Mrs's new Kona EV I often feel a bit nauseous.
My daily is a modified MX5. It's rumbly and noisy, but I'm fine in it!
A few passengers, initially my wife too. Tends to be high regen has more of an effect too with the head bobbing!
This was my experience as well. High regen takes a lot more effort and concentration to get right and keep smooth. Especially at the start.
Once you get more experience it does improve of course but the constant modulation as a driver can (may) still be noticed by passengers. It is almost imperceptible to the driver because they know what their right foot is doing and how it will affect the car.
Even when OPD drivers insist they “git gud” it can still be a very subtle “bobbing effect” for some passengers.
Yeh it’s the regen, once you get used to not just lifting straight off if you are one pedal driving, it gets better.
WHy would you turn regen off?This is why I have it turned off in my polestar, along with ‘creep mode’ turned on so it behaves exactly like a normal auto.
The exception is the EQC which I can change the regen level from nothing to fill in 4 increments using the ‘gear shift’ paddles on the steering wheel so I don’t need to feather the brake pedal when going down hills.
a 99hp model would be a good 2nd car around these rural parts, nice and small and narrow for all the tiny lanes but enough umph for the 60mph A roadsLooks like the Dacia Spring is getting some significant power updates so it actually functions as a car.69bhp and 99bhp models
Brake pedal still regens. So does cruise control which is great for downhill speed controlWHy would you turn regen off?
Using it add's approx 30 miles to my trip before i need to recharge.
just get used to it.
