- 25 May 2008
- North Wales
Yes a model Y.
Range is essentially determined by speed and the size of the front of the caravan and raw battery capacity. Weight and length doesn’t really make much difference. Wind also has a material impact as you are essentially towing a parachute.
I’ve got a standard 7ft6 wide caravan and if I’m on a long run, and tuck it in with the trucks at 56-60, it’s about 135 miles from 100% with a buffer (e.g. 145ish miles to zero).
Slower roads extends it out although stop start can drop it down as the caravans fiction brakes will come on when you slow down/stop.
Some cars with 100kwh batteries are doing 160-170 miles. Model Y only has 75 usable.
Most chargers mean unhitching, although the layouts on some mean you don’t or if they are not busy, you can just block them. For example, the expansion at Peterborough services just added 2 tow through bays, although I am sure they’ll be in use by numpties without a trailer when you want to use it because the spaces are bigger.
I just park the caravan next to the charger, I don’t mess around with parking in caravan parking or anything like that. It genuinely takes 2-3 mins to hitch up, it’s really not that big of a deal.
What I would say is the model Y doesn’t charge as quickly as other cars and as you do have to stop more often, I’d recommend the Kia/Hyundai over it. That’s also why I’m interested in the new iX3.
You can get compact caravans, Eriba is a popular one which has a pop top so it’s lower and narrower. Someone who has a 100kwh Fischer Ocean got about 190 miles towing one. For me, that’s good enough, I’d be more than satisfied with 170-180 miles range.
Thanks that's really interesting to hear real world experience of them, i know for me anyway i'd need to stop myself by 130ish miles of range as that must be getting on for 3 hours of driving.
Yeah i've been looking and Tesla are lagging behind quite a bit with their charging curves nowadays compared to the competition so be worth getting something that can sustain a decent high KW speed up to 60-70% like most of the other newer stuff can.
