Same, I can't actually remember the last time I regretted upgrading so soon.Really regretting upgrading so far, it's got quite a few annoying bugs in it. Safari needs to be restarted occasionally, and smooth scrolling in most browsers only seems to work when it wants.
I think it'll be the same as when BMW introduced the new grills; you never fully like them but you'll get used to it.And I still dislike this new Liquid Glass look and left aligned text :/
There are some settings in System Settings > Wallpaper, but it seems like you can only change the font, font weight and whether the clock shows or not. Doesn't seem to be a way to reduce the actual font size of the clock.Does anyone know how to change the size of the font for the clock at the login screen. It's heinously big.
On the iPhone you can make it smaller.
How do they let clowns make these design decisions?
Bump,Any way to get the Brightness and Volume Up/Down to appear back into the middle of the screen, rather than just below the system icons (and or bigger)? Really, really annoying having it moved after all these years.
rp2000
I very much doubt it.Bump,
Any workarounds for this?
rp2000
I'm finding I'm having to Force Quit applications quite regularly and the Apps replacement quite often doesn't want to actually show me any apps...this release felt nowhere near ready.
