Lian Li O11D Mini (v1/original) with top mounted 360mm AIO
great, so the Lian Li HydroShift II is wireless? we are about to do a lian li build for my son with a v100 vector case, but I skimpped on the top aio because the lian li aio 360 that says it is wireless is £203 (elsewhere) So we just plumped for the
Thermalright Aqua Elite 360 Black ARGB V3 which is £100 less than theHydroShift II, still, I might try and find the extra cash to get the same as you since the asetic looks so good! did the offsets come with the case?​
If I didn't get the hydroshift then I could afford the strimmers, did you get the strimmers from here, or elsewhere?​
Hey threepwood... so - I needed the offsets for my case (Lian Li O11D Mini) as it's VERY tight up there - think most reasonable sized Lian Li cases should be ok without them.. if you need them you can google for Lian Li Offset Brackets (RB01) - and that should help - think they were around £10.. but this likely isn't needed in the vast majority of cases..
I got everything from Overclockers (all the Lian Li fans, strimmers, AIO, GPU, CPU and new PSU! LOL!) - like just using the one place and had very good experiences with their CS before.
thanks dude, I mostly buy from ocuk, for the same reason, excellent CS experiences, tbh the prices are usually matched toelsewhere too. It's just sometimes, I have virtual cash sitting about in wallets
so just received a new stream dock so thought I'd post a quick video of the current setup - also decided to switch to the Lian Li O11D Mini v2 (white) but it's on pre-order with OCUK and should have it on or soon after 20/10/2025:
Could you tell me in a little more detail how the AIO installation went on the top? I have an O11 mini too and I would really like that same AIO. I haven't bought it yet because I was afraid it wouldn't fit. If possible, add a picture of the back of the case. Did you use that extender to fit the AIO? I thank you in advance for your attention.
It’s a very tight fit! - you need offset brackets to fit the 360 radiator up top (Lian Li make them called Lian Li RB06 - or you can get 3D printed ones) - I couldn’t fit all 6 - but fitted 4 of them which is more than enough to secure the radiator. I used the other 2 brackets to fit the rear 120mm fan.
There is a couple of variables which will depend on how difficult it will be to fit… the main on being how deep your vrm on your motherboard is - I’ve possible got the worst case going as I have a gigabyte z790 auros pro x which has a very thick vrm!
I’ll take more detailed photos for you tomorrow and try and take some measurements with a caliper to give you an idea of clearance
