Sure.Yes, for the sound. Pump and coil.
hard to say from the video..What’s your opinion on my coil whine?
Obligatory - Ensure you undervolt your 5090, especially the FE card.Just upgraded my Tuf 4090 OG (Not OC...OG is the smaller Tuf 4090) to a 5090 FE.
The Asus had "tolerable" coil whine. The FE has almost zero. I'm pleasantly surprised with how quiet it is.
The temps aren't great, but it's a 2-slot card dealing with almost 600w, so there's that.
I have a lazy undervolt for heavy workloads: 85% power limit, +225 core. I'm not touching the vram because stock temps are already high.Obligatory - Ensure you undervolt your 5090, especially the FE card.
I go pretty conservative on my undervolt profiles so never experience crashing. Agree on memory temps, I haven't once touched the memory OC slider.I have a lazy undervolt for heavy workloads: 85% power limit, +225 core. I'm not touching the vram because stock temps are already high.
non at all from what I heardWhat’s your opinion on my coil whine?
Had all of the LC. Astral was the worst for both, really liked the card but had to return it. Pump on 100% all the time.Guys? Anyone with Astral RTX 5090 LC OC? Pump noise and coil whine?
After trying MSI and Gigabyte, all of them buzzed. But the Astral will be even worse, right? Is it worth trying?
Mind its a composite 'paste', not "pure" liquid metal. That might be the difference but would also be interesting what the thoughts of the forum were.Is this a problem? Someone tore down Xtreme Waterforce RTX 5090 AIO and Liquid Metal was applied on bare copper instead nickel plated. This is bad, right?
Reddit - Please wait for verification
www.reddit.com
