*** Official Ubiquiti Discussion Thread ***
Did you have these issues before updating to the latest version?
Yes and no. Yes - whenever I try to change up my G4 Doorbell including using an old WiFi 5 AP exclusively for it, all sorts of issues happen and it eventually self corrects. Though I still can't connect it to my Camera WiFi, it's defaulted to Unifi Wireless network. No - drops, high TX retires, weak and varying signal from my APs, tonight - WiFi connected but browsing didn't work at all.
Hmm. Could try rolling back? See if that's any better? Or comment on the UI forum with the issues you're experiencing etc
My APs did not enjoy the circuit tripping tonight. Had to reset to factory default and re-adopt. Was hoping POE just needed recycling on the switch but nada.
i would really like the new doorbell but i have a camera and on android i just realise that i am missing notifications and when i check the app is logged out. Does anyone have an fixes or ideas?
Log back in. I've never had any issues getting the alerts on my phone for the alarms I have selected. I find line crossing the most useful.
Only other thing I can think of is how do you access your system, via the portal or direct only. I login using the portal so it stays connected every when I am out of the house.
