What 'setup' are you using for security, or just exposing slink to the outside world with signups turned off? ANd which VM type are you using, I've got an older free oracle account so could spin up a VM as well.I have, yeah. Still a few missing features compared to regular image hosting sites, ie, you can now upload multiple images but there's no copy bbcode for all button etc. But the dev is quite responsive, and I've raised a few issues which he's fixed. I'll get around to raising a few more feature requests and no doubt they'll be implemented.
App wise, signups are disabled (actually need to double check that). I might redirect the signup URL to a page not found, on the to do list. I then have it proxied through Cloudflare, so the 'real' public IP is not exposed. I then use an explicit allow rule for port 443 allowing traffic from Cloudflare's IPs only, plus an additional allow rule for port 22 from my home IP for management.What 'setup' are you using for security, or just exposing slink to the outside world with signups turned off? ANd which VM type are you using, I've got an older free oracle account so could spin up a VM as well.
I'm running it self hosted (alongside immich public proxy as a secondary method) through a cloudflare tunnel and using cloudflare to limit access to everything but the 'image' sub folder.. but for hosted in a VM in the cloud that might be overkill!
I would make sure the Protect app is set to 'unrestricted' for battery optimisation and similarly, if your variant of Android supports it, whitelist the app to prevent background sleeping.it logs you out every few months though and i have no idea is the problem..
Thanks..App wise, signups are disabled (actually need to double check that). I might redirect the signup URL to a page not found, on the to do list. I then have it proxied through Cloudflare, so the 'real' public IP is not exposed. I then use an explicit allow rule for port 443 allowing traffic from Cloudflare's IPs only, plus an additional allow rule for port 22 from my home IP for management.
I'm using the Ampere instance which is forever free, running Ubuntu. It's extremely quick, and I've run my blog and a couple of forums from other VMs there for several years without issue. I did once screw something up and I wasn't able to redeploy due to free tier limitations they sometimes enforce, I just upgraded to a paid account which removes those restrictions but if you stay within their free tier limits you'll never pay a penny and I haven't yet.
Running it from home is an option, but free fast cloud? Why not? And it completely removes any security risk.
That's a typical message when you don't have a credit card assigned IIRC. If they're low on resources I guess they impose this, on the chance they get to charge you for something. It's the restriction I mentioned above.I tried to spin up an Ampere VM, but it kept saying there aren't enough host resources..
What shape are you running? I thought Ampere (VM.Standard.A1.Flex) was the only ARM option they have but I haven't dug through it much.Is there any downside to the Ampere, it does say it has 3000 compute hours and bandwidth limits, but not sure if that would affect me..
I've got a credit card assigned, it just says to try 'later' in their FAQ..That's a typical message when you don't have a credit card assigned IIRC. If they're low on resources I guess they impose this, on the chance they get to charge you for something. It's the restriction I mentioned above.
Thanks..Right, yeah the free ARM instances are more generous than the x86 ones, ie, you get more cores/memory IIRC to use.
Always Free Resources
Learn what Always Free resources are available to all Oracle Cloud Infrastructure users.docs.oracle.com
For spinning up a few containers on a VM, you're not going to notice any difference whatsoever, if anything x86 might be more beneficial as not everything is compatible with ARM yet.
If you don't give them your credit card they expect a certain amount of CPU utilisation before they get flagged for removal. I used to run a simple cron job which ran a script to generate CPU and memory load every now and then which got around it, but ended up having to sign up properly as I needed to get something running urgently and they had 'no' capacity. Convenient!
And for folks reading this, you can run UniFi Network Application in OCI, I did it for about a year without issue. Free hosting FTW.
Which quite frankly, is capable of a fair amount!4 x OCPUs and 24gb RAM is the max to keep under the free tier for a single VM..
Ooh, get her. Calm down Don Grumpy.Less image hosting chat, more Ubiquiti chat.
so perhaps as long as I can get out to the big bad web it will work?Yes, the Network Video Recorder Instant can operate without external network access. However, a UniFi or third-party gateway, or Layer 3 switch is required to assign IP addresses to the cameras.
