- 6 Feb 2019
It's a Ryzen 3700xA second hand card is probably your best bet.
There are CPUs with integrated graphics that you can buy, though not sure what your current motherboard is (if it's a board for Intel or AMD, etc.). They'll likely cost a bit more than a second hand GPU though, so may not be worth it for your situation.
Rog strix b450
16gb Ram.
It's been a decent PC for last 5 or 6 years. Shame to not get it going again. It's been running flawlessly with a 3080 till last week. If I can get it wiped. I might use it as a normal pc. Or maybe pass it on for someone to put a GPU in.
Its got a couple of Corsair 2tb mp510 Nvme in it. I could maybe use one on the new pc.
Would something like a GT 710 work. Seen them online for £10.
