- 23 Apr 2020
- Close enough to OcUK that my wallet hurts
Is that from the Austin?
Is it definitely a cooper head?Pray for me as I try and get valves out that are absolutely seized solid in the guides of this head...
So far I've probably wasted £7 worth of PlusGas, that stuff is expensive.
Plenty of useful and historical Identification info here
.I do like the earlier engines for learning things like head swaps. Not just the practical side if the gasket goes up the Swanny, but what tweaks were done in the day. Don't forget to let the insurers know about the 'modification..
I remember helping my brother swap out a Morris minor (van) engine for a Sprite engine, was a straight swap mount wise.
So it seems that for cast iron parts, citric acid dissolved in water, is every bit as effective as evaporust, and by comparison is basically free...
I dumped 250 grams of citric acid into about 10L of hot water and the difference it has made in just 6 hours is amazing.
Need to check what other metals it will work well with, without causing surface damage.
, new engine mounts, Millers Nano Drive, brand new shocks, top mounts, bump stops, springs, re-sealed the diff, Fuchs Titan diff oil, OEM gearbox oil, sevice light reset, replaced headlight washer pumps and their covers springs.
