BT Openreach hit a central heating pipe whilst installing fibre
18 Oct 2002
I had a very inexperienced BT Openreach (subcontracted to Kelly Communications) engineer drill through my central heating pipe late last week whilst installing my new fibre connection. In hindsight I should have turned him away when he greeted me by saying “i’m here to fit your WiFi’”. He managed to drill between the 2 pipes, bursting one of them and denting another. Cue lots of water until the pipe emptied after I turned the water off. They sent a plumber out and 7 hours later we had water again. He told me he had the pipe detector on the wrong setting.
Not been very impressed with the response, they promised a call yesterday, nothing came, today they called me and I’m finding them difficult already.
The major damage is to my wooden flooring, an area has blown, become raised and is considerably distorted. I have a continuous run of wooden flooring throughout my entire downstairs, in the lounge (where the pipe was hit), dining room, kitchen, utility room and hallway. No idea how they are going to repair the section of damage and it’s going to be a big job to replace it. Someone is calling me about repairing the wall first, they won’t assess all of the damage at the same time. Each job is being treated individually.
My wife works from home and needs a quiet environment for her work (not an office based job). I asked about loss of earnings whilst she couldn’t work and was told that wasn’t covered and I should contact my service provider. My service provider (Plusnet) has wiped their hands of it, nothing to do with them I am told. I’m not a compo face type of person but I didn’t cause the damage, they sent an inexperienced engineer and I shouldn’t be out of pocket for their mistake.
It’s all a bit of a mess. Has anyone else experienced an insurance claim of this nature? I would definitely appreciate some guidance.
Claiming your consequentional losses is a bit of a rough one and probably not worth the effort. (hoops to jump through showing that youve taken reasonable efforts to mitigate or reduce those losses for example).
In terms of their insurance putting it right, just get the details and keep leaning on them.
https://www.ceoemail.com/s.php?id=ceo-9593 - Email Openreach CEO a complaint. It will then get hanned off to Plusnet at highest level for it to be Case managed
Plusnet have breached clause 12.3.2. services which have not been provided with reasonable skill and care;
You will have zero luck in claim consequential losses as if only on a Residental service your in breack of 2.1.3. use the services for personal use in the UK (so don't use the services to run your own business) and in accordance with our Acceptable Use Policy;
they are not usually liable - I had/pre-empted a specific discussion with my bt installer - he recommended where to drill through an interior wall (3" back from door jam, radiator on other side)
but made it clear he would not be responsible if they hit.
Great idea, I have just sent the CEO an email. I should have thought of that before! Thank you.
You're assuming his Wife needs the internet to work.
It’s not internet related, my wife runs a business from home where she requires a silent environment. She would need to cancel all of her appointments whilst the work takes place.
I would imagine they have insurance for this type of thing, and it's a case of finding the right department. I think it's reasonable they pay for damages. He's admitted liability by saying he had the pipe tester on the wrong setting. Would it be obvious there might be a central heating pipe there?
Get some good pictures of the damage - I'm sure you have already.
Being vocal on LinkedIn appears to help get traction with customer complaints too, my feed has constant BT Group tags with people having a moan for some reason.
