Yep, it's not a 'fix', it's just to get you home, then replace the tyre - it will however last for awhile as a bodge.Thought the gunk/kit meant tyre then had to be retired even if it would usually have been plugged, but tw, only had slow leaks allowing me to get to garage&repair.
Anyone got personal experience of getting rid of RFTs?
Even when you've got a recess, it's a nightmare trying to get hold of the correct spare, jack and boot toolkit.No boot recess for the wheel in a 330e
Not really willing to drag it around in the boot taking up the usable space. Its the main reasons i got the estate, to counter the smaller boot on the saloon with the battery!
@Malt_Vinegar Same experience as Tamzzy. Changed my RFT’s in Feb 2023 after running them on the car since I bought it in July 2021. The car rides better, handles better, takes bumps and potholes better and is much quieter too with much reduced tyre roar and road noise. I had a slow puncture on my rear left but that was plugged in summer 2024 and it’s been great since. I fitted Michelin PS5’s and they’re still going strong even now and nearly 23k miles later. I do have a can of tyre goop in the boot but haven’t had a full on puncture in about a decade. I also have AA cover too in case the tyre is truly destroyed and can’t be sealed.ex-428i and 440i owner and yes, it's well worth it.
in the 8 years i owned both bimmers i've had 1 puncture (mostly city driving).
the RFTs don't inspire confidence in the car and swapping to the MPS4S/F1A6 improved the handling tremendously
not to mention that the ride is quieter and more comfortable as well
I've been looking for the kit for our countryman since we got it, and the proper jack is £170 on it's own! (And no idea which space saver I actually need as there are various ones between 16" and 19" which apparently all are fine with my 18" alloys)
They usually have a Black Friday deal so hold fire just now. You can also by map updates for a year as a separate update.Feeling glad my 320i came with go flats from factory
Going off a few comments earlier in the thread, I think I should give the BMW Nav a decent go. However, it's on 2020 maps so it may not be the most representative of what it could be. Then use the built-in Spotify and see if there's much/any sound difference from CarPlay vs native app, then weigh up if it's worth the £120/year or whatever it is full a full year of ConnectedDrive![]()
Yep I can see the map updates in the store at the moment for £80/year. AFAIU, there's a new combo package with full ConnectedDrive + maps for £120/year so hopefully a deal to be had at the end of November, very good timing as my trial runs out on the 30th NovThey usually have a Black Friday deal so hold fire just now. You can also by map updates for a year as a separate update.
^They often have the map updates and others in black Friday sales via the app
Yep but not the proper boot insert etc to fit in the boot.Have a look on here, many kits with or without a jack for various year Countryman's
Cheap Spare Wheels & Space Saver Wheels - Thewheelshop.co.uk
The wheel shop are the leading suppliers of cheap spare wheels, space saver wheels and steel wheels in the UK. Free delivery, Free fitting.www.thewheelshop.co.uk
Yep, I got a 2 month trial with the purchase of the car so that's available and working at the moment.You'll need an active connected drive subscription to use the cars Spotify app.
A subscription to use a subscriptionYou'll need an active connected drive subscription to use the cars Spotify app.
need to try wired car-play too (not taxing the phone to re-encode audio albeit losslessly), also thought inbuilt app (their sim) using your premium contract,Going off a few comments earlier in the thread, I think I should give the BMW Nav a decent go. However, it's on 2020 maps so it may not be the most representative of what it could be. Then use the built-in Spotify and see if there's much/any sound difference from CarPlay vs native app, then weigh up if it's worth the £120/year or whatever it is full a full year of ConnectedDrive![]()
