- 6 Sep 2016
Not on this monitor.
To each their own but I can tell you that text scaling works fine.
Windows text scaling is different to 1080p game resolution and game textures scaled to 4k.
It’s the launch fe edition so 10gb I think.The only thing that would worry me a little long term is that the VRAM isn't that great on the 3080, is it the 10GB version or the 12 GB?, so I'd definitely just treat yourself to a nice high refresh rate OLED 1440 monitor, at £450 the dell AW2725D is still a bargain! and it does up to 280hz, which gives you some room to grow into
you won't even need the 5080 super at 1440p, save your money and stick with the 3080. 5080 super will probably be something stupid like £1200, plus it won't even be out untill the end of Q1!It’s the launch fe edition so 10gb I think.
It’ll last me u til the 5080 super drops next year
But what is the experience like? You will have to turn down settings a lot.Which games do you intend playing? You are not going to be able to max out the latest games at 4k but do you really need to? Any game can use sufficient effects to crush any GPU. And older games will run just fine. And then there's upscaling.
I've been gaming at 4k for over a decade, since GTX 780 Ti days. In fact, I bought my first 4k monitor from OCUK in April 2014, a Samsung U28D590.
Again, I play at 4k and it's not a problem. Text size in, for instance, Sniper Elite 4 and Command & Conquer 3, is just fine.
Really?
It turns out I don't actually play any of this year's games so I fired up the Black Myth Wukong benchmarking tool. I'm using a RTX 4090 )driver v581.57) on a Ryzen 9800X3D. At 4k Borderless with High settings, Medium RT, and Performance DLSS I get 80 fps. At 4k Borderless with high settings, Medium RT, and Quality (66) DLSS I get 60 fps. No frame generation.
I think you need to rethink 4k gaming.
Yeah I’m going to struggle on for a few more months u til the supers are outif you going 4k you really want a 5080s
