New Bambu Labs P2S
I had a clog in in the P2S today, I've never had a clog in the A1 in over a year and many rolls of filament through it. At least it's pretty easy to get to the nozzle and extruder
Interesting. It clogged in the extruded? Must admit I was nervous ordering the P2S and considering waiting it out a bit to see if any issues emerge. I hope they don’t
Well I ended up buying one last night. Took advantage of the silly bundles with filament and bought about 8 rolls and a 0.2 hot end. I did want a 3d cf effect build plate but doesn’t look like the p2s specific ones are out. I know I could have used an p1/a1 version but will but another time.
Will have to get my A1 ready for sale at some point.
nice. I’m wondering if I’ll hold off a minute and let the Black Friday sale pass before I sell my remaining A1’s
I regret not doing the filament now as I wasn't sure how much I'd want to use the AMS, but having it and seeing all the possibilities makes me want to fill my shelves with spools galore.
I did get the 0.2 hotend and the HF 0.4 though.
I ended up getting an array of filament. Couple of ABS for 9 quid a roll(refill) couple
Of pla, some, pla silk plus and some petg all for a tenner a roll on spools! I will probably grab the amd ht in future and will probably get another amd 2 pro at some time.
Looks like the discount for bulk buying will be higher in a few days.
Sorry when I said that I didn’t mean bulk I meant highly discounted when you buy a printer. As above the 1KG Refill ABS for £9 and 1KG Pla/PlaSilk+/petghf for £10.50 I don’t believe has ever been that cheap. Maybe for refill(can’t recall what I paid for some pla refills when I bought 6 a short while ago but think they are £10.99 with the bulk discount for buying 6.
That discount is going up in a few Daly’s for Black Friday , may already have gone up
Does anyone use a paving slab to dampen vibration and noise? I currently have mine on a reasonably heavy set of drawers and it seems to vibrate a fair bit even on standard print mode. I have heard you can get a paving slab and a bit of foam and it makes a big difference. I will be putting on a sit stand desk thats a little less robust than the drawers. They sell for £4.20 in Wickes so might nip and pick one up on the way home.
I've never tried the paving slab approach, I always go for the soft solution. Generally use hard foam under the table legs which stops vibrations transferring down to the floor.
