Anyone have a rubber mat cleaner/restorer to recommend? I got some Koch Chemie Guf after watching a youtube video and they came up fantastic but are slippery. Despite the claims of non slip on the bottle I need to clean it off again!
We have had no rainIt's just residue from the rain water, or around my area, mist and fog. Unless it's completely bone dry, the car will only be perfectly clean for 2 days, tops. In the winter you'll get residue from the evaporating rain water, and in the summer you'll get sand and dust.
mist or fog. I still think it's just dirt kicking up off the surface of the roads that never get a good cleaningBlack pano roof - Okay to use Gtechniq Ceramic C2 (which I have to hand) on it or should I use some sort of glass sealant?
let it sit for 5-10 minutes
While waiting, spray wheels with Turtle Wax Red Line and let that sit
lambswool mitt
Wash the wheels with different microfiber mitt and wheel brush.
Clay bar on all bodywork
chamois cloth
Anybody got any suggestions of decent pre-wash to use? Preferably something I can buy at a physical shop at short notice, i.e. Halfrauds.
FYI, I won't have time to use snow foam for my next clean.
Cheers
Hmm, not available at somewhere like Halfrauds unfortunately. Does sound like something that's worth getting for the future though, so good shout.Many snow foams can be used as a pre wash through a sprayer.
I’ve tried a few different ones and I don’t think there’s any value in using anything other than Bilt Hamber Touchless.
I’ve posted results on it before on here, but it absolutely melts road traffic film in the winter, better than anything I’ve used before.
You can get similar results with other products but it just takes a bit more planning and effort.
I’ve been trying to have a think but I’ve only tried Polar Blast and found it pretty pants.Hmm, not available at somewhere like Halfrauds unfortunately. Does sound like something that's worth getting for the future though, so good shout.
Would you recommend any other products that I could get at fairly short notice, like from Halfrauds? I don't mind spending a bit more effort on it.
Thinking about it, I was planning on cleaning the car today, but might just leave it for next weekend, so I have time to order the better stuff that you mentioned earlier.I’ve been trying to have a think but I’ve only tried Polar Blast and found it pretty pants.
I haven’t tried the Halfords Advanced one, but their other stuff has reviewed quite well, so it might be alright.
@MrRockliffe could you recommend a sprayer to use for the Bilt Hamber Touchless please? I did have a snow foam lance, but I left it at the inlaws and won't get it back until Christmas.
Seen https://www.cleanyourcar.co.uk/ik-sprayer-ik-foam-pro-2 - will this be effective enough, or are there better options?
Also, what's the recommended dilution? This PIR and 0.5% stuff goes over my head honestly.
That makes a lot of sense, thank you!I use a cheap garden pump sprayer, but those foam sprayers are better. PIR in those pump/foam sprayers are just the dilution ratio multiplied by the capacity.
So if you have 1250ml of fluid in the pump sprayer, if you have a 2% PIR it's just 1250 * 0.02 so 25ml of touchless then the rest water to make 1250ml.
I tend to use 2% as the car is usually very dirty when I clean it, if it was a light coating of dust in summer, maybe 1% or lower.
