Caporegime
- 22 Oct 2002
- Boston, Lincolnshire
Yeah, I always went for chain driven cars, but that limits the pool of cars you can pick from.
It's not, but the AC Compressor pulley/wheel bearing seems to be done... I bought a shorter belt to bypass the AC Compressor for now, will slap that on tomorrow.
On the other hand, I didn't do the cambelt today, weather wasn't the best... I've some good news though, managed to secure a garage across the street, just need to fix the doors and see what's inside. Plan is to clean it up, insulate it, get a calendar with naked baes and I can finally work on cars/bikes in peace.![]()
Chain drive isn't always the best either. Just look at BMW and Jaguar 4 cylinder diesels. Belt drive is also quieter. Id much prefer on a longitudinal engine to have a belt due to easy access. Likewise on a small hatch with a tiny engine. Access is very easy for a belt change in those scenarios. I can do the belts on my daughters Punto in under two hours.
On a Massive engine squeezed into a small hole a chain is obviously the most logical choice.
My wife's first car was a Nissan Primera P12 and it stretched its chain on only 70k. I changed it on the drive in the snow and it took me for ever. Splitting timing chain covers, removing sumps etc. Plus the replacement chain and sprockets are more expensive.
Speaking of OEM vs other. I put a gates timing belt and water pump kit on my daughters Punto and it made a horrible noise. Found a new old stock genuine belt on ebay and stuck that on and it was silent again as the teeth were slightly different in design with a little indent and Gates are meant to be a good brand.
