Massively noticeable how have they not fixed it yet? Same problem every battlefield release? baffling.I have more issues with getting done behind cover than hit registration (although it’s clearly noticeable).
Has anybody managed to complete the support challenge where you have to damage enemies with the Sich G1 for so many thousand points? Used it nearly all the night last night as my primary and only got 90 points.. It's either bugged or the description is not correct.
I got to 400 odd trying to do it normally over the last two weeks, problem with it is it only counts direct hits so no burning cloud damage, gave up in the end and cheesed it doing the plant mines at vehicle swap to support then shoot the mines with the g1 exploit.Has anybody managed to complete the support challenge where you have to damage enemies with the Sich G1 for so many thousand points? Used it nearly all the night last night as my primary and only got 90 points.. It's either bugged or the description is not correct.
Tried this this morning and its not working for me.I got to 400 odd trying to do it normally over the last two weeks, problem with it is it only counts direct hits so no burning cloud damage, gave up in the end and cheesed it doing the plant mines at vehicle swap to support then shoot the mines with the g1 exploit.
Try a combo of a pressure mine plus a slam, the G1 sets the slams of easier couldn't get it to work with just the pressure mines, did it earlier today so it still works.Tried this this morning and its not working for me.
Had the same issue since launch rather annoying.Some challenges are still not tracking...
Been like this for months![]()
My biggest pet peeve is party sizes. Not being able to play with more than 4 friends without faffing is a massive oversight/annoyance. Playing portal with bots or custom servers is a rubbish alternative.
Certainly pushes my 9800x3d this game temps anything from 75-82
Snip
Yep that's the workaround we are doing but as you note, if any delay you go in queue. Also it's like 7 or 8 of us usually which causes more issues.Get them to join a game, as soon as they tell you what map is loading. Go into their party and quickly click " JOIN GAME ". You will join the game with them... If you do it too slow it will put you in a queue
Just as goosed as the main multiplayer. Plus you have to add in the tick rate being 30 until the last couple of sector reductions...Is the hitreg on Redsec goosed ? Played last night, full clip from my lmg into a guy and nothing, next round 20 bullets from my friends smg at the start two kills, we can't seem to keep it consistent?
From my own detailed research of last night, some folk are complete sponges other aren't, it's hard to guess what I'm fighting.
