BRSK
Damn... Sorry to hear that! The person who installed my Fibre Cable/ONT came one hour early and did a brilliant job. He even hoovered the area where he worked a little bit (using my hoover, but I did a more thorough job of it myself). Very happy! BRSK hasn't let me down (only downtime has been scheduled maintenance as far as I know). 6 months and nothing but positive experiences here... Contact BRSK and the police to investigate who the installer is and make sure they get punished for that. I ran my own CAT5E cable across to the other side of the room the day before he came and he noticed that haha.
Hi BuZ. Yeah you got lucky with your installer. I'm just glad I stopped the installation before it ended up being a disaster. So late yesterday, I 've had more senior installers arrive at my property and have assured me that the installer is being dealt as an internal matter and he also said the installer would be reported, so I feel I need to move on from that awful incident.
So the install has now been rescheduled to early Dec as I'm away for a week. I've also been given the BetterWifi mesh system for free, so all good.
Since the install date has been pushed back, I've got a bit of time to think whether it's worth still sticking to the same old router location or changing it. Since you've mentioned it BuZ, I'm now thinking if it's worth running CAT6 cable before they arrive and have the router more in the centre. Will just need a simple diagram as to how it will be laid out and what devices would go where based on my diagram above.
  1. Does anyone know whether an ONT can be moved easily if this is a better option at a later date?
  2. Would it be worth me removing the Brsk router and just plugging in the mesh system directly into the ONT?
The fibre cable is kinda delicate (it can't be bent/twisted as much as an ethernet cable and it cannot be punctured or subject to weight otherwise the light won't shine through it properly, so they will recommend having the ONT installed on the wall where the fibre cable enters your property). However, there is nothing preventing you from asking them for more information regarding that. Personally, to keeps things simple, I would suggest running your own ethernet cable like I did (CAT5e can sometimes unofficially handle up to 10Gbps on very short runs (10 metres or less, I think) because CAT5e is just CAT6 cable without the extra shielding and insulation).
Also. I'm unsure about the mesh system because I use my own router (Asus router and have a repeater connected to it). Although... When I got my BRSK installation - I switched from Virgin who gave me a woeful experience, they gave me the TP Link Aginet EX820v (the V means it is a VOIP capable router). I think they are now issuing a Sagemcom router instead, but I've heard mixed opinions about the router (probably buggy firmware or maybe user error). Hopefully your installation goes smoothly and you get a good experience! :D
I'm also unsure about how you will run the cable, but semi-central is the best most people can achieve due to the design of houses and the location of electrical outlets. I currently have my main router on the opposite side of the living room (the ONT is installed on the opposite side) where I used to have my Virgin Hub (which I used in modem mode with my own router).
BuZ, thanks for the advice. Please take a look at the edited diagram which I shared earlier on the forum — apologies that it’s not perfect. My plan is to have the installers run the fibre cable through the exposed cellar ceiling, which should be straightforward. There’s a power socket available in the cellar where the ONT can be placed. From there, I’ll run a CAT6 Ethernet cable up to the office on the first floor, where the new Brsk router will be located.
By positioning the ONT in the basement (a more central spot), I’ll have flexibility: if I later decide the router isn’t in the ideal location, I can re-route the CAT6 to a better position and use a switch at the original router point instead. What do you think?
Pink line = Fibre cable running from outside to the ONT
Red cross = Power Socket in the cellar
Blue line = CAT6 Ethernet cable from ONT to the Brsk Router location
Also regarding routers, I've read that there are many wifi issues with Sagecom routers, specifically connections dropping, so should I ask for Brsk's tp-link router instead from the installer? I know it's WIFI6, but I'd rather have a more stable connection.
That might be a good idea. I mean, you could ask BRSK for the TPLink router with hopes that they may give it to you (they probably have a leftover surplus stock of them left, but the main router given to customers is the Sagemcom one before that it was an Icotera router/Technicolour router which were both only WiFi 5 capable, instead of WiFi 6/7). The TPLink router is decent, although most ISP provided routers are okay-ish (I had Virgin's Hub 3 released back in 2017/2018, the one with the flawed Intel Puma chipset), but BRSK do at least give you a decent one (the Sagemcom router probably needs a firmware update and people don't bother to change the default settings like I do and you probably will).
Also in regards to that ethernet cable, as long as the ethernet cable doesn't get snagged, heavily bent or something like that, you should be okay. I tucked my 10 metre ethernet cable under the carpet around the edge of the room (as tidy/neatly as I possibly could). Just make sure the ONT/Fibre cable isn't in a place where there is a risk it might get damaged, since the ethernet cable is more cheap to replace than BRSK replacing the fibre cable (I buy my ethernet cables from RhinoCables on EBay/Amazon). I switched away from Virgin back in early summer this year, although BRSK began rolling their service out in my town back in 2022/2023, so I've been following BRSK since around late 2022. They got stalled due to something though, so installation in my part of the town got paused and other places got installation instead.
Thanks BuZ for the helpful info. I've been with Virgin from the days of telewest and I've got to say that the current Superhub 5 has been absolutely rock solid so I hope people can understand and appreciate that having read so many horror stories about Brsk's routers, specifically the Sagemcom, you begin to have doubts about whether moving to Brsk is the right choice.
  1. Are you suggesting that I keep the ONT location only upto the entry of the property to avoid it getting damaged or will I be okay to take it to my chosen location shown in the diagram?
  2. If you had a choice, would you go for the the TP-Link (wifi 6) or the Sagemcom (wifi 7)?
  3. Since Brsk are giving me free mesh for 18 months, which router brand has a better mesh wifi system?
  4. I have no problem in updating any firmwares or change of settings, but firstly what settings would I need to change and surely if this is all that was required we wouldn't have so many complaints and you would see a lot people advising users to do this?
  5. Apologies if you've mentioned this already, but one thing I forgot to ask you firstly your full setup and secondly how is it running stability and speed-wise (wired/wifi)?
1. Yes. The ONT is best kept at the point or close to where the fibre cable enters your home from your nearest street pole. The diagram doesn't give me much information about your house, but you could ask the installer/engineer for more information when they come on the day of the installation, they will probably suggest something similar to me. I'm an IT Technician (qualified, but don't work as one).
2 and 3. I think the Sagemcom router is given by default for all new installations since around late September or early October, but I could be wrong. I mean there is nothing stopping you from haggling with BRSK about that to ask for the TPLink router, but I do think the mesh system is TPLink and not Sagemcom (can't see anything on their website about Sagemcom mesh systems, unless I'm not looking in the right place).
4. I'd suggest setting separating the SSIDs (Network names), so you have one for the 2.4GHz connection and another for the 5GHz connection and so on. I'd also check for other wireless networks around you and select the best possible channels and occasionally check on it a few times to make sure you have the best channels selected. Simple stuff like that.
5. 99.99% uptime, only downtime I've experienced is scheduled maintenance, that's it. Unless a major fault happens, but that's expected with technology, so no complaints here from me. I'm located near Manchester. I will post my speed test result from inside my router (I have the 500/500 package).
1. Yes. The ONT is best kept at the point or close to where the fibre cable enters your home from your nearest street pole. The diagram doesn't give me much information about your house, but you could ask the installer/engineer for more information when they come the day of the installation, they will probably suggest something similar to me. I'm an IT Technician (qualified, but don't work as one).
5. 99.99% uptime, only downtime I've experienced is scheduled maintenance, that's it. Unless a major fault happens, but that's expected with technology, so no complaints here for me. I'm located near Manchester. I will post my speed test result from inside my router (I have the 500/500 package).
1. That's fine, I'll speak to the Techy about the best route and location, but due to my home being fairly large, if it was installed at the entrance of the home, I believe I'd need to run a 30m ethernet cable to bring it to my chosen location for the router. Though not sure if such a length of ethernet cable would cause any issues in speed, ping etc. What information would you like to know about my home?
2 and 3. Brsk have said the following on their website: For all of our broadband installs, you will receive either an Icotera i4850, a Technicolor DGA0122, TP-Link EX820v (BetterNet2000 only) or Sagemcom Fast 5598 router. For BetterWiFi, we install either Icotera i3550, Technicolor OWA0131, Agent HX710 Pro or Sagemcom Fast 281 devices (depending on the router installed) to work alongside the main router - I can rule out the Icotera, Technicolor routers, so that leaves us with TP-Link EX820v or Sagemcom Fast 5598 routers with Agent HX710 Pro or Sagemcom Fast 281 mesh systems respectively. The dilemma I have is what router and mesh system to pick from these two brand choices.
4. Ahh yeah I've done that anyway with the Superhub so that won't be a problem at all, but I was thinking of more advanced settings that may need changing.
5. Thanks. That's really good speeds. But are these wireless or wired and if wireless how far is your router from your testing device?
That's a speed test from the WAN port (newer ASUS routers have a built in speed test in the admin panel). Wireless depends on your house/apartment and obstacles/interference. I've currently taken my ASUS router offline because I've flashed it with Open WRT to increase the transmit power and stuff so I can get more range out of it, but getting used to the admin panel in Open WRT, so I'm using the TPLink for now. It's decent, but my ASUS router is better in my opinion. Also, that's new, I guess they are issuing some kinda mesh system with the Sagemcom routers. I mean, you could always go for you own router and bypass BRSK's equipment completely (obviously not the ONT, lol). But yeah. Give it a test, if you have issues, invest into your own equipment (Black Friday/New Year deals are close).
Oh my apologies as all that time I was thinking you're using one of Brsk's stock router and that it works well. What was your reason to switch to the Asus router and which model is it? FYI, I currently also have an Asus RT-AX82U also wired up, but to be honest, it's been problematic, with regular disconnections, reboots or poor wifi. Not sure though if this router could be used to replace the Brsk stock router.
Mine is an ASUS RT-AX59U (AX4200), it only has a 1 Gigabit WAN port, but I don't intend to go above 1 Gigabit because it would be overkill for my use case. In regards to bugs and stuff regarding your ASUS router, you could have glance at SNBForums, since that has an ASUS router section, there are probably other similar forums. Also DD WRT (a more simplified version of Open WRT may be available for your router, but install it at your own risk if you decide to go down that road).
Cheers mate. To be honest, I'm not afraid of replacing the firmware, so will be happy with DD-WRT. However, apologies, but my question was could my Asus RT-AX82U replace the Brsk stock router? Also why did you end up getting another router? What issues did you have with your stock router in the first place?
I used another router instead of the Virgin Hub3 because it couldn't handle more than 12 devices wirelessly without locking up (I upgrade my router every 4 to 5 years, or so). The TPLink router is better than any router I've ever had from Virgin, that's for sure, a modified version of TPLink's stock firmware (by BRSK) has been flashed onto it. I had to adjust the DHCP timer from 2 hours (default) to a little over 1 day on the TPLink router because 2 hours DHCP seems too fast for a home router.
Like I said, it's decent, probably the best router I've had given by an ISP (only ever been with Virgin though). My dad's the one with his name on the bill, but I pay him money per month for BRSK and bought a TV box for him. My dad used to be paying £80+ for the base package on Virgin. Absolutely ridiculous... :(
However, I've had experiences with the Netgear WGR614 back when my dad originally joined Virgin in 2008-ish, then the Netgear WNR2200, then got an upgrade to the Superhub 1 (awful, worst hub ever, lol so I bought a Netgear WNR2200) which got replaced with a Superhub 2ac a few years later when we upgraded to faster internet/for a package renewal (my dad is clueless when it comes to techy stuff, so I had to ring Virgin and get new deals for him), the Superhub 2ac eventually died, so we got a replacement Hub3 in 2019-ish, which I used a few different routers with.
It's funny, but your history sounds almost the same as mine - Although I joined Telewest (late 90s/early 00s) before it became Virgin. So I've been through all their modems and Superhubs, but from personal experience, I would say the Virgin Superhub 5 is one of the best routers I've had, with great stability and wifi signal all the way upto the attic.
I've joined SNBForums, but waiting for approval from admin. Having looked into the matter, it seems that I will be able to use the Asus RT-AX82U router to replace the stock router, although can't go over 1gb, but that should be fine as I'm on the 1gb down/up anyway. Hopefully once my account is approved, I'll be able to find out whether I can flash DD-WRT to my Asus model soon.
Oh btw, what's the difference between Merlin and DD-WRT?
Merlin is a modified version of ASUS's firmware, I think, with a few more features added, though I could be wrong, but my router doesn't support it. DD WRT is a spinoff of Open WRT (although DD WRT is available on less routers than Open WRT). DD WRT probably has way more features to be honest, but like I said... be careful like I said though because it can be difficult to go back to stock firmware sometimes.
Also, aren't the Superhubs 4, 5 and 5x made by Sagemcom? The Superhub 3 is made by Arris and the Superhub 2 and 1 are made by Netgear. I have a friend in Netherlands who is on Ziggo, which is owned by the same company (Liberty Global) as Virgin and he used to have the Hub3 over there, same thing, but repackaged/rebranded.
Merlin is a modified version of ASUS's firmware, I think, with a few more features added, though I could be wrong, but my router doesn't support it. DD WRT is a spinoff of Open WRT (although DD WRT is available on less routers than Open WRT). DD WRT probably has way more features to be honest, but like I said. Be careful like I said though because it can be difficult to go back to stock firmware sometimes.
Also, aren't the Superhubs 4, 5 and 5x made by Sagemcom? The Superhub 3 is made by Arris and the Superhub 2 and 1 are made by Netgear. I have a friend in Netherlands who is on Ziggo, which is owned by the same company (Liberty Global) as Virgin and he uses to have the Hub3 over there, same thing, but repackaged/rebranded.
I think the Superhub was made jointly by Broadcom and Sagemcom, but unlike the Sagemcom Fast 5598 router, the Superhub 5 has got good reviews overall.
I've not been able to find anything to say that the DD-WRT or OpenWRT support the RT-AX82U, so most likely they don't support it, but the AsusWRT Merlin website states there are Forks/Variants which support RT-AX82U V1 and V2. However I'm not sure whether I have V1 or V2.
Also I thought in order to replace the Brsk router, I would need a DSL router? Don't forget that the RT-AX82U is not DSL or does this not matter?
  • Like
Reactions: BuZ
BRSK doesn't use copper phone lines, the fibre cable is the line coming into your house. Unless you plan to have a home phone (attached to your router), you don't need to take the phone package out with BRSK. One benefit of it. Most people don't use landline numbers anymore, they use their mobile number or have a separate mobile number as a home phone. Quite simple to fix that problem.
So what you're saying is that we'll be fine with a NON-DSL router? No we don't need a house phone at all.
  • Like
Reactions: BuZ
Yeah. The ONT works similar to Virgin Media's old cable modems (I remember the Ambit 256 vividly, loved that modem, lol). All the ONT does is translates the optical signal into ethernet/electrical signals. You can essentially call it a fibre modem. It's a Nokia XGSPON ONT XS-010X, I think.
That's brilliant thank you. Yes I remember the ambit modems...they were the flat ones like the one below haha. I even remember the Motorola Surfboard modems.
