Just bought 'phase 2' bits, so made a trip to the local music bits/timber supplier:
* Tuners = decided rather than the £143 for Schaller m6 minis (18:1), I'd have a look at the Gotoh equivalent SG381 minis (16:1) for a total of £40 for 7 in chome. I figured that I could cope with any weight difference for that price difference.
* Two 4x4x1000mm carbon fibre structs to add some support for the body spar and the neck
* An extra piece of lining - I'd really need some additional thickness so this will add another bend layer. When I do the perfling (the binding around the edge), I need to route a hole in the side, so if the lining is too thin then the side of the guitar fall off
* Truss rod - self explanatory. The neck will also have a section of the carbon fibre in there. This is smaller than the solid body as the neck joins at fret 14.
I'd originally budgeted for the little version of my schaller M6 135 locking tuners on my solid body guitar, the M6 mini that's not a locking tuner. However looking at the tuners in person, plus being ok with chrome for this build rather than black, I decided they're decent enough and the saving means I now have the dual piezo 'pearl' pickup for under the bridge and still came in under budget. I think he under charged me, or discounted a little, I now still have more budget for later according to my spreadsheet.
