FAFO in action
I've limited mine to 600w. Worked better than undervolting to achieve the same max power output of 600w. Amps and temps on connector good with the Matrix bios better again, higher clocks and steady. Only using that power on BF6 for max fps with no frame gen.They have already started going pop....
Odd timing really![]()
You know, even under stock, they spike well over 600W, as I have seen spikes as high as 808W on the Wireview. I do have a Wireview Pro 2 due next month, and I am in the first batch for them.I've limited mine to 600w. Worked better than undervolting to achieve the same max power output of 600w. Amps and temps on connector good with the Matrix bios better again, higher clocks and steady. Only using that power on BF6 for max fps with no frame gen.
Other single player games I undervolt and use MFG.
Id like to think anyone running a 800w bios is monitoring the connector? I know, you'll crack the jokes![]()
me in a few days
Expensive paperweightme in a few days![]()
Yeah, saw that. Just checked connections again, all good. Monitoring with wvp and temp sensors from motherboard on psu and gpu.You know, even under stock, they spike well over 600W, as I have seen spikes as high as 808W on the Wireview. I do have a Wireview Pro 2 due next month, and I am in the first batch for them.
Using the Matrix bios, I have seen spikes well over 900W. So, I'll leave mine with the normal BIOS, I think.
What card are you using again?I want to try out my 5090TIthen regret it later
Heaven/Furmark, initially. Heaven is good for changing values as it running till it crashes. Not sure re 5080, but can't overclock the 5090 memory too far, it doesn't let you.Guys best way to test 18000mhz memory OC on RTX 5080? ta
Suprim Liquid, so can't use the 800W vbiosWhat card are you using again?
Good news/bad news...Suprim Liquid, so can't use the 800W vbios
Good news, as at least I'll have one 5090 if the worst happensGood news/bad news...![]()
Not yet, will flash it at the weekend. What kind of uplift are others seeing?I've been keeping up with people flashing their 5090's with the new 800W Matrix vBios
anyone on here done it?
Genuinely lost all interest in current GPUs lol, perhaps even future. By the time my 4090 is too old to run games well the gaming space will have shifted to a big enough degree that a dedicated GPU probably won't matter any more as AI/ML will be doing all the heavy lifting anyway and we will be "gaming" on any types of machines.
(memory prices are absolutely shocking)Just wonder is a 750w psu this one Corsair RM750x 80 PLUS Gold, 750 W Fully Modular ATX Power Supply purchased back in 2020 want to run a msi 5070 ti ventus, my cpu is a 10700k not overclocked?
People I know 5-7% but running on aorus masters and at over 700wNot yet, will flash it at the weekend. What kind of uplift are others seeing?
