- 5 Jun 2007
- extremes.spacious.indelible
I give up on this XG. Tried to install in the loft and it just won't adopt, unless it meshes with one of the other APs. Internet suggests it's quite picky about cable runs but my tester is showing the run as good. I've tried but it just doesn't want to play ball in my network.
Edit - on second thought. Could it be the pinout of the RJ45? I used some random Cat7 cable for the XG when it was by the stairs but the attic run is 6E which the electrician installed when we bought the house. And then there is the patch panel and cable - probably reaching but worth checking out.
Could be!
Reterminate both ends to the same standard (B club here), and see if that helps things.
I know a sparky who lives by the method “as long as it’s the same at both ends it doesn’t matter!”
). If that doesn't work, I'll bung the U5 LR in the attic and bring the XG back to by the stairs which should hopefully solve the crowding issue.
